Author Topic: swopped engines but....  (Read 3729 times)
Offline smeg760
Re: swopped engines but....
« Reply #10 on: 14 November 2010, 09:56 »
that was it it has an idle air controll valve I think the agg uses solenoids or something like that.
« Reply #11 on: 15 November 2010, 11:09 »
head im 90% sure is same AGG to 2E, differences are all in the inlet manifold. as above, it wont run on the later management without a crank sensor. alternative is to change the engine loom and management for 2E stuff, either by replacing entire engine loom or chop + splice as above.  its a lot of work though either way you go about it
Offline harlemex
« Reply #12 on: 15 November 2010, 14:39 »
Right geezer this is entirely possible but it will require a bit of concentration and time.
I just put a 2e in my adz and used an agg loom.
You will need the 2e engine block loom and the 2e ecu and you will also need a 2e ecu connector plug with  maybe 10cm of wires poking out of it.
you will also need a couple of pin ejectors because you need to swap all the wires round on the 2e engine loom multiblock connector to corespond withe the correct wires on the agg loom.
The agg is sequential injection whereas the 2e is not so you only need to use one of the injector wires but you will need to use two of the redundant injector wires to piggyback up to the ecu and then use them for the cold start injector live and somthig else cant quite remember what cos i dont have my notes in front of me they are at work.
But i can send you copies if you would like and talk them through on the phone if need be.
Also the reason you need the 2e ecu multi plug is the 2e ecu has cut outs on it presumably so you cant plug the wrong ecu into the agg loom.
Oh there is one very important wire to remove it is a live on the agg loom that would fry your 2e ecu you cut it ond use it for the evap valve live and cold start live and the other thing your 2e has that the agg doesnt that i cant remember at the moment,
Or the other option is just fit a 2e engine loom if you can get one , there is aircon but its just for clutch no? james...
As easy as that aye?  :laugh: :laugh: :laugh:
« Reply #13 on: 15 November 2010, 14:58 »
oh other issue with swapping entire loom, is your car might have the engine and lighting looms integrated. if thats so then you cant use a 2e one direct as it has engine loom separate from lighting loom. that means to fit it you would have to unwrap the old loom and swap all the lighting looms into the 2e loom
Offline daphney
« Reply #14 on: 15 November 2010, 18:06 »
thanks for all the replys
i have got hold off agg head & will build engine & fit at weekend
so will just be puttin 2e back in shed for now
hopefully will run fine & i dont want to be ripping all electrics about
will tell u how i get on :wink:
« Reply #15 on: 16 November 2010, 09:46 »
mk2 digi owners will be all over that 2e engine like a rash if you decide to sell ;)
Offline smeg760
« Reply #16 on: 24 November 2010, 11:06 »
How sit gan ?
Offline daphney
« Reply #17 on: 15 January 2011, 17:48 »
ok firstly sorry for very late reply  been ill & bad weather killed my effort
but now is done & runs sweet :smiley:
i rebuilt old engine with new head
so now i still got loads of spares left
will 2e gearbox work on all mk3 8v gti ?
if not wat is diff as i gonna try & save all mk3 gti i can till run out of bits
& 2e engine still here so if any interest pm me
thnx for all u info & help
