Author Topic: front bumper removal  (Read 7665 times)
Offline The Doc
  • E63s Estate - Vito Sport
« on: 12 November 2010, 05:23 »
Hi Guys,
So how do I remove my Mk6 GTD front bumper please?
Thanks in advance ;-)
Offline Snoopy
  • Moderator
  • Geoff.
Re: front bumper removal
« Reply #1 on: 12 November 2010, 07:51 »
Try a search i have asked this before and got an answer  :wink:
Here you go Snoopy
Remove radiator grille
Remove front bumper cover
–   Remove bolts -4-.
–   Remove bolts -2- (pointing upwards) on left and right of wheel housing.
–   Remove bolts -3- from wheel housing.
–   Remove bolts -5- and -6- from underneath.
Further removal is only possible with the help of a second mechanic.
–   Pull front bumper cover -1- out of fasteners of guides on left and right of wing -arrows a-.
–   With the aid of a second mechanic, pull off front bumper cover -1- parallel -arrows b- from vehicle.
–   Disconnect connectors from all electrical components.
Notes and work sequence for parking aid are located in → Electrical system; Rep. Gr.94
Instructions and work specifications for the Park Assist system can be found in → Electrical system; Rep. Gr.94
–   Disconnect washer fluid hose connectors (if fitted) → Electrical system; Rep. Gr.92
« Last Edit: 12 November 2010, 18:51 by Snoopy »
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline Steve30
  • Ed30 .
« Reply #2 on: 12 November 2010, 08:09 »
Hi Guys,
I sent you a PM Doc but no response??  :undecided:
Tiguan quicker than the Golf
Offline crazysingh
« Reply #3 on: 03 June 2011, 12:22 »
Hi guys,
I'm looking to get 3 door mk6 tdi, It is a cat-d salvage.
I'm going to repair it myself (mostly) only the paintwork will be done by the bodyshop.
So can you please send me any document or instructions similar to the one posted here before.
Need instruction on how to replace the Radiators on golf mk6.
Any help would be great
thanks  :smiley:
Offline DRC
« Reply #4 on: 03 June 2011, 13:35 »
If the radiator is damaged it must have taken a beating.
Hope you got a good price!
'13 Audi A3 8V S-Line - Dakota Grey - 2.0TDI 150 - MMI Plus Nav - Bang&Olufsen - Comfort Pack - LED Lighting Pack - Comms Pack - Model and Technology Badge Deletion
