Author Topic: Changing Bootlid Glass  (Read 2220 times)
Offline Charge
  • Into Notion, Out of Motion
« on: 10 November 2010, 12:52 »
How hard is it to remove the Bootlid glass and fit a different one? And if it's easy, what tools and what else do I need?
Thanks.
Offline tony_ack
Re: Changing Bootlid Glass
« Reply #1 on: 10 November 2010, 13:03 »
Not too difficult. You need to push the seal over the lip that holds it in place, from the inside. Once you've got it started, continue around the glass pushing the seal out. Once you're about 2/3 of the way round, the glass should pull off.
I'm sure there's some clever plastic tool that may be able to help you, but I'm hard and northern, so used my fingersĀ  :smiley:
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 10 November 2010, 14:22 »
I'm told the hard part is re-fitting it.... You need some string and loop it round the rubber and tease it back in...
Dare some someone else will give you a better idea!!
For More Info Click To See;
Offline Charge
« Reply #3 on: 10 November 2010, 15:33 »
Are there any places that would do it for me? Or is that too specialised. I don't want to go breaking some glass.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 10 November 2010, 15:41 »
Most Glass places or bodyshops!!
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #5 on: 10 November 2010, 17:20 »
its really easy especially the rear screen. I use a screw driver but a plastic wedge will do. Push the seal over the inner lip. Once you get going its pretty easy, with a little pressue it will pop out when you have done about two thirds. To get it back in get some cord into the seal and cross it over then put the bottom edge in and pull the cord from the inside. Get some one to put a little pressure on it from the outside. Job done!!
Offline Charge
« Reply #6 on: 10 November 2010, 17:52 »
Sounds pretty easy but I am confused by what you mean when you say cork? Like.. how?
Offline richard s
« Reply #7 on: 10 November 2010, 21:23 »
oakgreengolf didnt write cork he wrote cord aka string  :smiley:
as stated start in a corner and use something to lift the rubber over the lip and then its a case of working your way round and your window is out then the cord/string sits in the slot in the window rubber then you put the window back in by pulling the cord to pull the seal back over the lip
if your removing your bootlid take the glass out first as it is easier then trying to remove it once the bootlid is removed
Offline Charge
« Reply #8 on: 10 November 2010, 22:36 »
I could have a crack at it I suppose! And if not, bodyshop it is!
Offline Sam
  • Sam I am
« Reply #9 on: 10 November 2010, 23:06 »
You may as well, if your skipping the old one?
