Author Topic: Single Headlamp Grill  (Read 2098 times)
Offline Chris_D
  • www.hijackbristol.co.uk
« on: 04 February 2005, 22:46 »
How do you convert to a single headlamp grill?
Also I have some electric windo motor and mechanisms fitted with two wires coming out and i also have the switches, just the resistors mmissing? this is what i've been told, is this true and where can i get some?
1990 Mk2 8valve
Offline Chris_D
Re: Single Headlamp Grill
« Reply #1 on: 04 February 2005, 23:00 »
Relay sorry not resistor!
Offline sellers
  • Daz Works in Health and Beauty
« Reply #2 on: 04 February 2005, 23:45 »
single headlamp grille change is simple, simply unplug your inner spots an tuck the wiring somewhere, then unscrew 4 screws on the top of the grille and it wil come off leaving your outer lights
Can't think of a funy or whitty comment
Offline Chris_D
« Reply #3 on: 05 February 2005, 00:02 »
do you not use the inner spots at all then? do you not have side lights just head lights?
Offline pegasus
« Reply #4 on: 05 February 2005, 16:16 »
Sidelight bulbs are in your headlights ;)
The inners are just spotlights
Really easy job to swap to single headlight grill, takes about 10 mins
1.8 20VT GTI
