Author Topic: Coilovers....  (Read 22521 times)
Offline clipperjay
Re: Coilovers....
« Reply #10 on: 23 October 2010, 13:53 »
Kw's Thom really no sh!t mate, I've owned, sat in GAZ, FK's, Koni's, Wetiechs, Blisten.
Kw's are the best IMO! V3 or even V2's will be a good fast road track would be V3 for sure!
Offline Lewy
Re: Coilovers....
« Reply #11 on: 24 October 2010, 18:49 »
Pardon my ignorance what are you using the car for?
I've driven on fully adjustable Avo's and Koni's and found them both quite harsh, but not as harsh as a set of FK Highsports in Joe's Mk2.
Last year I went for KW Inox V1's (height adj only) and they are by far the best coilovers I have ever driven on. There is no banging around when hitting bumps in the road, and after a long journey it doesn't feel like I've got spinabifida.
Offline clipperjay
Re: Coilovers....
« Reply #12 on: 24 October 2010, 19:49 »
Same for me :wink: People just don't believe that KW's are a perfect balance.
I love how the feel of the ride tightens up if I want to plant my right foot, but at cruising speeds it provided just the right damping on harsh bumps.
I don't work for them, but the next set will be Kw's for me again!  :cool:
Offline bmm
  • Be patient... I'm an idiot
Re: Coilovers....
« Reply #13 on: 24 October 2010, 20:57 »
I sprung (no pun intended!) for the Eibach Pro Street S coilovers earlier this year and they're tops - the dampers are made by KW so I suppose the only bit Eibach about them are the springs and various tweaks.
Even though my eBay-coilover-buying mates jaws hit the floor when I told them the price, I wouldn't swap them - the ride is so perfect in every way.  Handles big bumps with ease and my spine is completely intact!
Offline Neo Badness
  • Feet are for pedals
Re: Coilovers....
« Reply #14 on: 24 October 2010, 22:18 »
Koni's, highly rated.
Infinitely better than the KW cheapy copies I got.
Noticed on the members discounts Spax doubly adjustable suspension ( height and damping) 15% off :cool:
http://www.golfgtiforum.co.uk/index.php?topic=147187.0
Offline Organisys
  • Old and Slow...
Re: Coilovers....
« Reply #15 on: 25 October 2010, 12:28 »
KW as you seem to be able to afford them. v3 will allow you to adjust them to your exact requirements too.
Weitek are a good value choice, I have them on my G60 and are height and damping adjustable for around £550 ride very well too especially considering the car is quite low.
 :smiley:
Offline Diamond Hell
  • Opinions я Us
Re: Coilovers....
« Reply #16 on: 25 October 2010, 13:55 »
KW as you seem to be able to afford them. v3 will allow you to bu99er about with them endlessly without finding the right setting.
Fixed.
Offline sparks03
  • Look at the veins in that
Re: Coilovers....
« Reply #17 on: 25 October 2010, 16:27 »
Don't find Konis too bad.I do a fifty mile round commute daily and the Golf pootles along just nicely on the sh!t stretch of tarmac that is the M6
<br />   Heaven is 13 feet long
Offline Thom89
  • Looking for an "Icebreaker"
Re: Coilovers....
« Reply #18 on: 25 October 2010, 19:13 »
Fixed.
Dammit! I thought I was on to something with the KWs... any truth in the rumor? please tell :rolleyes:
Thom
  • Opinions я Us
Re: Coilovers....
« Reply #19 on: 25 October 2010, 23:24 »
You've got 15 settings on each, before you start frigging with the spring rates.
What in all f*ckery makes you think you can get that right for A roads, B roads or motorway, let alone track?
B8 struts and good quality appropriate springs might be more sensible for road and play.
Let's face it, what are you going to do, corner weight it every time you take a different passenger?  Weigh your luggage whenever you take anything out in it?  Can you imagine the amount of winding down you'll need to do if you give Chuff a lift?
Coilovers will corrode and seize - it's in their nature.  Struts are simple and fixed, developed for the best compromise for approximately your car on approximately the sort of roads you might typically drive.  Good quality items should 'just work'.  You know, like your Mac.
Keep It Simple, Stupid.
