Author Topic: Stu's Mk3 1.8t [projectninetynine]  (Read 39681 times)
Offline Dan_GTi8v
Re: NEW! Mk3 1.8t Project :D
« Reply #30 on: 08 November 2010, 14:19 »
so it hasn't gone bang yet then? :P
Offline LazyLunatic
  • MK3 20VT Project
« Reply #31 on: 08 November 2010, 15:13 »
Nope! Started the wiring, not looking too bad, going to get it finished this week. Need to look at the ecu as i think it needs he immobiliser removed.
Offline Dan_GTi8v
« Reply #32 on: 09 November 2010, 03:42 »
I just got a 1.8t aum loom off ebay so I'm gonna be having a crack at this soon too :P Following the guide for the mk2 on clubgti, been told its almost exactly the same as they use the same fusebox. Only problem is I wont know if I'm successfull until I hook it all up!
I got topher to do my immob and map for me, maybe worth asking him. Although he does a mobile service Plymouth maybe a bit far for him to go though :P
Offline Dan_GTi8v
« Reply #33 on: 09 November 2010, 18:19 »
What intercooler are you using? I was thinking of one from a merc sprinter van, you know if they will fit infront of the rad?
Offline lemski
  • 16v
« Reply #34 on: 09 November 2010, 18:25 »
They fit on a mk2 so they should fit on a wider mk3
Offline LazyLunatic
  • MK3 20VT Project
« Reply #35 on: 09 November 2010, 19:25 »
Using the same intercooler as mine :)
Offline Dan_GTi8v
« Reply #36 on: 09 November 2010, 19:41 »
what are you using on yours? :P
Offline Dan_GTi8v
« Reply #37 on: 13 November 2010, 17:49 »
sooooooo its been a week isnce you started the wiring :) going ok or are you still finding bits of engine all over the place? :P
Offline LazyLunatic
  • MK3 20VT Project
« Reply #38 on: 14 November 2010, 17:27 »
Hola. I'm using an ebay £50 intercooler. 2.5" ends. Sits in the front end nicely with a little trimming of the bumper and a length of 40mm ali angle to bolt it to the steel crossmember.
Haven't been working on it this weekend, been away to Bristol (Shopping with the missus for her B'day).
Offline Dan_GTi8v
« Reply #39 on: 14 November 2010, 19:07 »
ah ok, happy bday to her then :P
