Author Topic: Silver Mk3 16v GTI  (Read 43275 times)
Offline adzgti3
Re: Silver Mk3 16v GTI
« Reply #100 on: 09 June 2011, 10:53 »
looks spot on mate , defo a big improvement  :cool:
Offline VR6_Wherry
« Reply #101 on: 09 June 2011, 11:08 »
How the fcuk did you get the headlining not to like it was all folded on itself round the handle and light areas? I made a mess of mine!  :sad:
Looks spot on really liking the inside of that  :cool:
Offline SoundillusioN
« Reply #102 on: 09 June 2011, 11:10 »
Wow, not seen this car since it was first posted... Massive improvement, car looks so much better than it did when you first got it... great work. :afro:
Offline MattMK
« Reply #103 on: 09 June 2011, 13:29 »
Looks like a good job mate, is the adhesive brush on or spray?
Offline GrandMstRamRod
« Reply #104 on: 09 June 2011, 14:21 »
yh i f**ked mine up, whats your technique, as i f**ked the handles up aswell!
Offline dazzawest1987
« Reply #105 on: 11 June 2011, 21:36 »
my first attempt was a real cock up, but the material was to thick and the spray glue i used was crap. i changed the type of material i used, i got mine from www.fabric-online.co.uk and changed the glue to wickes contact adhesive and that made it a lot easier, although i still couldnt get the front part right, where the lamp is i kept getting loads of slack. ended up having to cut a slit in the material which fortunately you cant see as it faces away from you.
cheers mate, just need to get round to ordering the passenger harness and it'll be sorted for the time being
cheers mate, big fan of your car
« Reply #106 on: 11 June 2011, 21:40 »
adhesive comes in a tin with a scraper, i used a mix of the scraper and a brush
done a lil bit at a time and took my time about it, makes a big difference using contact adhesive and thinner slightly stretchy material
« Reply #107 on: 11 June 2011, 21:41 »
thanks for all your comments   :smiley:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #108 on: 11 June 2011, 22:16 »
love the liner mate, going to be doing mine, ill take a look at this what u have used
where did you get the grab handles and how much were they ?  had a guy on ed38 asking silly money for some so i passed :grin:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline stow1985
  • 'when im cleaning winders'
« Reply #109 on: 29 November 2011, 20:59 »
As said before your headlining looks really good,
didnt think to cut and shut mine, but then again my fabric is patterned which was a bad idea  :rolleyes:
