Author Topic: curbed alloys  (Read 4137 times)
Offline jerseyal
curbed alloys
« on: 17 October 2010, 14:43 »
hi all i have two curbed alloys on my mk 6 gti anyone know if they can be repaired and where to go
Re: curbed alloys
« Reply #1 on: 17 October 2010, 15:07 »
Monzas or Monza Shadows (or different wheels again)?
Monzas should be easy enough to repair if the marks aren't deep but Monza Shadows are altogether more difficult to get 'as new' again due to their diamond cut finish and the shape of the rim.
Normally any kerbing will mean the rim will have to be milled which makes the hole cutouts slightly different to the other wheels. Not too bad if you put both the repaired wheels on the same side of the vehicle.
There are a few members on here who have had satisfactory refurbs on Shadows so I'm sure they'll be along to advise.
I had a set of Monza IIs refurbed on a previous mk5 Golf by Pristine. They did a good enough job but the finish didn't look 100% factory. However they said the lacquer they put on was probably better than the original stuff!
I've also known someone have a repair on a Monza II that had a chunk of metal out of the rim. The repair consisted of having a bit of metal welded into the rim and then it was milled and looked 100% afterwards. I was really surprised how well it came up. This was also done by Pristine as they were one of the few places that could do the diamond cut finish at the time.
Offline AGB
Re: curbed alloys
« Reply #2 on: 17 October 2010, 15:10 »
You didn't say whether you've got Monzas or Monza Shadows or how bad the damage is.
If you've got Monzas and if it's minor, I found this pretty useful: http://www.autopia-carcare.com/realwhda.html
I just grazed the edge of my back right wheel on a wet night and the graze, scuff was about half an inch long and the techniques and materials quoted in the link above produced a really good result.
If you've got the diamond cut Shadows, it's a bit more complicated. I was referred to 'The Wheel Specialist' but never used them, preferring to do the work myself.
Hope this helps.
MK7 Clubsport S, 981 Cayman GT4, MK7.5 GTI TCR
Offline jerseyal
Re: curbed alloys
« Reply #3 on: 18 October 2010, 08:17 »
hi guys they are monza shadows thanks for the tips gona get some quotes then decide what to do
Offline gossa
Re: curbed alloys
« Reply #4 on: 18 October 2010, 16:23 »
Just steer well clear of Spit and Polish in Kent, they are cr@p and will ruin your wheels.
Offline MAW73
  • Used to like Golfs :-)
Re: curbed alloys
« Reply #5 on: 18 October 2010, 17:00 »
Where did you get yours done then in the end then Gossa.......... ?
2014 BMW F20 M135i, Auto
Offline R32UK
Re: curbed alloys
« Reply #6 on: 18 October 2010, 17:33 »
I had some done by spit and polish and they came back perfect... although they only had minor cosmetic issues
Offline Jimble
Re: curbed alloys
« Reply #7 on: 18 October 2010, 17:40 »
Has anyone ever posted pics of a monza shadow they've had refurbed? or better still a before and after, would be good to see the results.
Offline Phil1980
Re: curbed alloys
« Reply #8 on: 18 October 2010, 17:45 »
I'm pretty sure there was before and after pics of monza's in the mk5 or cosmetic sections within the last couple of weeks.
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline Phil1980
Re: curbed alloys
« Reply #9 on: 18 October 2010, 17:47 »
