Author Topic: Which oil should i use for piston slap engine? Need advice...  (Read 4585 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Which oil should i use for piston slap engine? Need advice...
« Reply #10 on: 18 October 2010, 19:35 »
Aex piston slap is very common, skirts wear, oil usage is still minimal, so likely to be that,  oil... thicker oil just acts as a muffler, and reduces the lubrication efficiency when cold,  so your engine is ultimately going to last longer on normal oil.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
