Author Topic: 3C8 035 730A bluetooth kits  (Read 18918 times)
Offline am1w
Re: RNS510 version c and 3C8 035 730A bluetooth kits
« Reply #40 on: 09 November 2010, 12:35 »
I'm also tempted by the bluetooth kit but i'm a little concerned about extra rattles etc, god knows i've got plenty already. :angry:
It is strange you should mention rattles.
I had a couple behind the speedo binnacle etc.
But once Darren fitted my RNS and Bluetooth kit, they all disappeared. :smiley:
Offline Jimble
« Reply #41 on: 09 November 2010, 12:40 »
Hmm, might be worth getting it fitted just to get rid of a couple of em! :grin: is the mic in the overhead bit? and does it take much trim removal to get there?
Offline am1w
« Reply #42 on: 09 November 2010, 12:48 »
Headlining and A pillar trim has to be released but not removed. Darren did this perfectly with no damage. He is very precise with his work. Highly recommended.
Offline p3asa
« Reply #43 on: 10 November 2010, 17:34 »
Cheers Herbie. I'm tempted to sell my Fiscon and get one of those as sometimes my call list doesn't get populated on the RNS which is annoying. Although my voice button on the steering wheel works to answer and drop calls.
Go for it p3. It's simply brilliant. :smiley:
Did you get the newer VW one?
Offline am1w
« Reply #44 on: 10 November 2010, 18:31 »
I don't have the latest one which shows text messages. But it does everything else perfectly. Voice control etc
In short, I don't have this one.
http://cgi.ebay.ph/VW-Neue-Volkswagen-Bluetooth-FSE-UHV-RNS510-PREMIUM-/170513928782
« Last Edit: 10 November 2010, 18:43 by am1w »
Offline p3asa
« Reply #45 on: 11 November 2010, 13:45 »
Thanks for the link.
Offline oldman
« Reply #46 on: 11 November 2010, 15:54 »
Thanks Darren for supplying me with the 3C8035730A BT kit.  Installed it last weekend and it works like a dream with my Samsung g600. However,after an autoscan with VCDS it found 10 faults.CAN gateway 5 faults and Telephone 5 faults probably down to incorrectly coded control modules.My codings are CAN-EDA87F06400612000003.Telephone-020000000000000000000000. Can you throw any light on the codings. It looks like the Telephone module is coded for a charging cradle.
Hi Darren    After playing around with the Telephone module coding,although I did not try every combination,I ended up with-
                020000000100000000010000   This cleared all the CAN GATEWAY faults and left only 2 TELEPHONE faults-
                1.Cellular Antenna    2.Control Module for Cellular Telephone
                I'm quite happy to leave these unless some one else knows a different coding. Just one more thing, the mic button on the steering wheel
                only enables voice control for the Telephone, where as the voice button on the RNS510 will enable voice control for Radio,Nav and
                Telephone. Your thoughts on this would be much appreciated.
                 Thanks Rob.
Offline mortygt140
« Reply #47 on: 11 November 2010, 18:06 »
You need to go into the module 16 Steering wheel and change the 5 to a 7 or if you have dsg then it needs to be an 8, this will enable push to talk(voice control) on the RNS510
This is the coding for that module mate so will give you some clear idea of what needs to be set, some of them I haven't got a clue.
Byte 0 Language:
00?
01 German
English 02
03 French
04 Italians
05 Spanish
06 Portuguese
08 Czech
07-09-FF not allowed
Byte 1. Voice Command:
00 activated
01 disabled
Byte 2.Type Microphone:
Parameter 00 1 / microphone VW
01 parameters 2 / microphone VW
10 parameters 1 / microphone Audi
02-03, 11-13 parameter set 3-4 / VW and Audi
Byte 3. Diagnosis antenna:
00 active
01 inactive
Byte 4. Diagnosis fixing Laptop (Überwachung Baseplate):
00 active
01 inactive
Byte 5. Mute (cooperating):
00 active
01 inactive
Byte 6. Control unit for the mobile phone preparation (module three keys):
00 Module 3-button activates / SMS possible
01 Module 3-button inactive / SMS possible
10 3-button activates / SMS is not possible
March 11-button inactive / SMS is not possible
Byte 7. Multimedia function:
00 BT Audio Active / Active Multimedia Context
01 BT inactive Audio / Multimedia Assets Background
10 BT Audio disabled Active / Inactive Multimedia Context
11 BT inactive Audio / Multimedia Background Off
Byte 8. Type of registration of mobile phone:
00 Supporting THB
VDA 01 Support
10 Support Paragon
Byte 9. Function call for help:
00 people with disabilities
01 activated
Byte 10. Fuel Type:
00 Unknown
01 Gasoline
04 Diesel
05 LPG
06 natural gas
08 Electricity
10 hydrogen
Byte 11. Vehicle type:
00 M1
01-05 M2 and N1-3-3
Darren
Offline oldman
« Reply #48 on: 12 November 2010, 16:59 »
Thanks Darren for the telephone coding list,it came in very useful, so much so that I was able to clear all the fault codes.The coding I used was-
020000010100010000010100. However,I am still unable to use the Mic button to control ALL voice control functions,it will only operate voice for
the Telephone, although the voice button on the RNS510 will control radio,nav and telephone.The steering wheel coding is 0001802(dsg).
Cheers Rob.
Offline Danwai
« Reply #49 on: 12 November 2010, 18:48 »
Hi all linky to items in stock
http://www.golfgtiforum.co.uk/index.php?topic=169384.0
Darren
Hello Darren,
Sorry to be a pain (emailed you this morning - but noticed that you were logged on) just wondering if you have any more Bluetooth units left for sell and fitting?  my mate is placing an order on a bluetooth kit with his dealer tomorrow, was considering joining him - but would have to fit myself, would prob. screw it up... so would much prefer to get one from you and ask you to fit as well...
