Author Topic: Wheel Refurbing Questions!  (Read 53424 times)
Offline Dec
Re: Wheel Refurbing Questions!
« Reply #20 on: 13 October 2010, 21:09 »
Yeah just seen that dude! Watching your thread :)
Your refurb looks great! I just worry far too much about everything, and this is one of those things!
The bit that I'm going to worry about most is the masking up, paint removal (should i rub down, or paint stripper btw?) then the curbing repair. If I fook up the spraying, then I can always just keep trying it till I get it right! But the initial stripping is whats going to make me panic, as usually I wouldn't bother doing anything about them :embarassed: but I want to get them sorted out to look smarter!
Thanks for all the tips/guidance/help so far guys! Might go to halfords at the weekend and get a few of the bits I need to give it a go on my spare wheel :cool:
Offline jeremybarker
« Reply #21 on: 13 October 2010, 21:11 »
Hi Dec,
Just reading this post.
If it helps i didn't use any paint stripper on mine. I started with 60 grit sandpaper to cut through the lacquer and do most of the work, i then worked my way down until the primer on the wheel was nice and smooth. After this and making sure you clean every and i mean every bit of dust off, triple check this part, you then want to acid etch prime the wheels (Halfords £10.99 in the large metallic red tin) so the paint keys to the wheel properly. You can then paint normal primer over the top and carry on with the flatting process.
Any scuffs,dents or chips in the wheel were flattened (gently with a hammer) to remove any burrs and then filled with a metal filler (also in Halfords), then sanded to a flat finish before the etch primer went on.
http://www.golfgtiforum.co.uk/index.php?topic=168372.0
HTH
« Last Edit: 13 October 2010, 21:13 by jeremybarker »
Making up for lost time
Offline Dec
« Reply #22 on: 13 October 2010, 21:15 »
Awesome! Thanks dude! From the looks of these wheels, they have had paint over paint, as they are a slightly darker silver/greyish than standard (which I like) but nowhere near as dark as anthracite :undecided: So I think it is going to take a lot of rubbing to get them down to the right level to be able to patch the curbing :sad:
Suppose all I can do now is give it a go! Tbh they are probably the easiest wheel to do this on as it is such a simple design :tongue:
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
« Reply #23 on: 13 October 2010, 21:24 »
I just stuck a few pics and words about my wheel refurb in my ride thread over here that might be of use:
http://www.golfgtiforum.co.uk/index.php?topic=168952.msg1572657#msg1572657
Pretty much all the stuff I used I got from Halfords.  I spent extra for the enamel primer and colour but not entirely sure if it's worth it.  I used way, way, way more paint than I thought I would, so maybe factor that in - buy more than you think you need!  But yeah, it was a mix of the wet+dry sandpapers, then the usual primer, colour, lacquer and that was all there really was to it - I didn't attempt any curbing repair though.
Patience is probably the number one thing, a rushed job will show through especially if you hurry through some steps especially prep!  But it's so rewarding when it's done and they're on the car, so I'd say go for it  :cool:
they look good [thumbs up]
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
« Reply #24 on: 13 October 2010, 22:31 »
Pictures speak a thousand words let's see the damage and the rims overall.
For what it's worth I've never re-furbed a wheel in my life, this was my first go, no practice runs just straight onto the wheel, if I can make a half arsed job on the fiddley RA's you'll be fine.  :cool:
« Last Edit: 13 October 2010, 22:33 by jeremybarker »
Offline godsANGER
« Reply #25 on: 13 October 2010, 22:40 »
mine are foobards mix of curbing (previous owner) and lacquer pealing very old pics not even lowered so the lacquer peal is much worse
I am going to be doing them Black so i need to fill the curbs  :sick:
Also sorry for hijacking  the thread saves me posting and asking the same questions  :tongue:
Offline Dec
« Reply #26 on: 13 October 2010, 22:43 »
Don't say sorry lol, this is a general thread that hopefully may be of use to others :)
Few crappy pics of mine, will get close ups tomorrow..
This one is the least damaged:
Offline Dec
« Reply #27 on: 13 October 2010, 22:46 »
Oh, and they now have tyres on obv, so will need to do some masking work first. Tyres are slightly stretched so at least I have space to get between the rim and tyre!
Is masking tape and newspaper suitable, or will I need something more 'hardcore'?
Warning, mega huge pic (6.1mb) but its big enough to see the stretch :rolleyes:
http://farm5.static.flickr.com/4107/5025877156_68ee142fa3_o.jpg
Offline godsANGER
« Reply #28 on: 13 October 2010, 22:47 »
clean your shoes lol  :grin: joking
how you refurbishing them ? colour or you just repairing then going le natural ?
Offline Dec
« Reply #29 on: 13 October 2010, 22:49 »
 :tongue: They are the pics my mate sent me when he asked if I wanted to buy them, so not my shoes lol
Going to strip them all completely, repair the curbing, then try to match that colour as much as possible. I don't want a hugely bright silver, more of a slight grey but not as dark as anthracite :)
