Author Topic: why does my water temperature go down when i switch my heater on?  (Read 2248 times)
Offline fozziie
  • psn: fozziie
my cars never been up above 90 degree's according to the dial. I used to have a MK3 Astra with a dodgy thermostat, had to keep using the heater trick with the windows down, that said, i only had the astra 2 days before i picked a fight with a mitsi warrior and came off significantly worse!
Offline javalin
>water pump slowing down
water pump is driven by the aux belts on some and cam belts on others - so won't slow down.
Ah it must be winter - thermostat issues starting already!
+10 thermostat issue - stuck open or shut.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Khare
  • The bear that khares
J
It'll be stuck open mate  :grin: If it was shut the engine would roast like a Christmas turkey. Also water pump can slow down due to the wear on the fins that push the water.
Offline sharki786
  • GOT BOOST??
waterpump was replaced in january.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Len
Never seen this in my car so as said its the thermostat.
www.sas.org.uk
www.the-ace.org.uk
Offline harlemex
Khare is spot on with his info. 100 percent.
Offline A7 UFO
I did exactly the same with an astra that I used to commute in
