Author Topic: mk3 poly bush top mount on a mk2  (Read 5186 times)
Offline popleyruss
Re: mk3 poly bush top mount on a mk2
« Reply #10 on: 11 October 2010, 01:10 »
do they come with the bearings?
yes mate they did
Just plain dubbin
Offline Ben Lessani
« Reply #11 on: 11 October 2010, 08:44 »
have a search, i did a post about top mounts and it lists what mk3 parts you need
« Reply #12 on: 11 October 2010, 11:45 »
if you have coilovers they will prob fit straight onto them, just need the MK3 GTI threaded bush. if std shocks then you need early mk3 gti upper spring plate as well
1H0 412 341 - MK3 GTI upper spring plate, small size
1H0 412 365 A - threaded bush
N 105 352 01- top nut
Offline Mew
« Reply #13 on: 11 October 2010, 19:31 »
Are the OP's top mounts not for the rear?
Offline Khare
  • The bear that khares
« Reply #14 on: 11 October 2010, 19:33 »
No, rear come in 4 bits, 2 for each side (upper and lower).
VeeDubGTI16v
« Reply #15 on: 11 October 2010, 19:36 »
paul had problems with these on his mk3 track car, have a look in the trackday section
i had some jom mk2 style ones years ago and they were excellent, but the bearings only lasted 6 months, don't think they are really designed to work with the impact from poly, although the mk3 bearings might put up more resistance
« Last Edit: 11 October 2010, 19:39 by veedubgti16v »
Offline Mew
« Reply #16 on: 11 October 2010, 19:42 »
I know, that's what it looks like in the bag to me
« Reply #17 on: 12 October 2010, 15:26 »
nah you can see the bearings in them, they're MK3 GTI type front mounts
Offline popleyruss
« Reply #18 on: 12 October 2010, 19:19 »
yeah they were bought for my mk3 vr6 and neve got round to fitting them thats why im asking if they will go on my mk2
Just plain dubbin
Offline dan_apps
  • too low for british roads!
« Reply #19 on: 12 October 2010, 20:50 »
polybush on a topmount i must say im skeptical, especially on how long it will last!
