Author Topic: What Engine is this?  (Read 4324 times)
Offline The Mighty Elvi
  • I'm better than you today.
Re: What Engine is this?
« Reply #20 on: 09 October 2010, 23:32 »
I preempt DH here, but why don't you just put in an ABF engine?
Are you getting the 1.8T for peanuts?
Offline chrisr103
« Reply #21 on: 09 October 2010, 23:35 »
Think he is getting the engine,Box & turbo for £700 ish as long as the offer he put in has been accepted
<a href="http://giffgaff.com/orders/affiliate/chrisr45" target="_blank"><img src="http://giffgaff.com/banner/01_80x15.png" width="80" height="15" alt="Get a free giffgaff Sim" /></a>
« Reply #22 on: 09 October 2010, 23:42 »
Just the loom to sort out then.
Tidy.
Jonathan.
« Reply #23 on: 09 October 2010, 23:44 »
Not a bad price, I take it no ecu with it however.
Offline danny_p
« Reply #24 on: 10 October 2010, 00:36 »
big problem with the vw scene is as so menay engines just drop in plug up and work anything that requires more is called difficult :(     the correct term is not quite so boreing.
for an engine conversion to be intresting   nothing should plug or bolt up dircetly and meany bits need fetteling
difficult is when  you have to reshape the hole the engine may possobly eventualy fit in, then you have to fabricate ALL the mounts, make your own adaptor plate for the gearbox,  compose a clutch out of random ones,  make your flywheel fit the clutch.  then try and get a starter motor in there somehow and then make your own exhaust. before thinking about driveshafts  :smiley:
1.8T is easy done in a week,   3 days is plenty
all the VW's have gone bar 1.
Offline chrisr103
« Reply #25 on: 10 October 2010, 12:56 »
I think he is also getting the ECU But not too sure.
Offline emery1990
« Reply #26 on: 10 October 2010, 14:44 »
I'd imagine the wiring just to take a while, to just id all the wires, then its easy to just them where they belong, I thought my ms install was going to be hard, buts it looks very simple.
