Author Topic: Start up problem!?!  (Read 2019 times)
Re: Start up problem!?!
« Reply #10 on: 13 October 2010, 10:42 »
yeah thats an ady or agg lump, which means it has a crank sensor. you'll find it buried right down the bottom of the block next to the gearbox, need to put jack under engine and remove the front engine mount bracket to get to it. check the wiring from it, by now the wiring will likely be all brittle with bare wires hanging out.  plenty other things it could be though, ecu relay, coil (unlikely since rev counter no move)
does the pump prime when you turn the key 1 click?
00513 - Engine Speed Sensor - G28 - Idle RPM Too Low B (crank sensor)
01249 - Cylinder 1 - Injector Fault -N30 D
01250 - Cylinder 2 - Injector Fault -N31 D
01251 - Cylinder 3 - Injector Fault -N32 D
01252 - Cylinder 4 - Injector Fault -N33 D
looks like you have a wiring issue, maybe the round plug on the engine is loose? look for anything that's obviously broken.  however could be these faults are old, did you clear them then see what comes back?  oih i see you mention lpg, maybe that's got something to do with the injector faults logged above...
dom069: those are std MK3 GTI upper strut retaining cups :)
Offline Okram
« Reply #11 on: 13 October 2010, 17:21 »
Just arrived from work, I'm going to take care of him now. Thanks so far.
Offline Okram
« Reply #12 on: 13 October 2010, 20:20 »
Today I bought a new coil and the car started. Computer shows clean page as well.
Thanks rubjonny for you replies.
