Author Topic: tricky one! help pls!  (Read 4797 times)
Offline Dan_GTi8v
Re: tricky one! help pls!
« Reply #10 on: 07 October 2010, 19:26 »
if you change to electric windows you will need to fit the mechanisms as well which could be expensive, and although not done it myself i'd imagine it to be a bit of a mission
A majority of door cards no matter what spec have push out or at least markings on the back where the winders go so it would be very easy to fit your old winders and just swap the handles over for your old ones
Offline dom
  • Back in a Mk4
« Reply #11 on: 07 October 2010, 21:44 »
+1 to that!
« Reply #12 on: 07 October 2010, 22:13 »
+2  :smiley:
Offline Bellend
« Reply #13 on: 07 October 2010, 22:42 »
Just drill an adequate hole for the winders and use your handle covers. Will look exactly the same.
If you're near I'll do it to for you.
Where all my moneys went.
Offline TalisaJade
« Reply #14 on: 07 October 2010, 22:44 »
Thanks hun! Jus wanted t know about the handles really... Whether my current bog standard ones would fit! I imagine drillin a hole for the winders isn't difficult! Think ill b okay hun but will let u know,appreciate it :) x x x
Go & f**k Yourself To Whoever Reads This!
Offline Bellend
« Reply #15 on: 07 October 2010, 22:47 »
Meh Derby's miles.
Where the electrical window switches are if it has them, pull that away. That will pull off, couple of screws underneath, possibly have to take the speakers out, I can't remember. Unscrew the lock pull's and then pull the door card from the bottom then eventually up a little and it should come off.
Offline Khare
  • The bear that khares
« Reply #16 on: 07 October 2010, 22:48 »
Aren't you like 16?
Offline Bellend
« Reply #17 on: 07 October 2010, 22:52 »
Aren't you like 16?
Like nearly 18.
Offline Khare
« Reply #18 on: 07 October 2010, 23:01 »
I swear you were 15 when you were banned....About, a year ago...
Offline TalisaJade
« Reply #19 on: 07 October 2010, 23:02 »
Banned at that age!? Banned at any age!? U must b mad haha!! Even so though Khare bear... He still must know more than me! :rollseyes:
