Author Topic: VAG COM  (Read 4446 times)
Offline BanburyCo
Re: VAG COM
« Reply #10 on: 26 October 2010, 18:57 »
I have my copy now saying try before you activate etc.. all the time.
I tried control module finder took about 20minutes but never showed anything in log apart from engine ?? and abs but nothing else was getting written away, is that how it should be?
Offline LowlifeDubber
Re: VAG COM
« Reply #11 on: 26 October 2010, 20:44 »
that batch file works but its not very good. i made a vbs file which does a much better job ;)
Thats right,thats what i did in the end(was a while ago and forgot)They are the d1,d2,d3 files if i remember rightly?
Re: VAG COM
« Reply #12 on: 27 October 2010, 10:19 »
yep, you need to setup a script to keep an eye on these files and re-copy them if they get deleted. the vbs i made also watches for vagcom.exe and closes itself after vagcom is shut down. using a vbs also means you dont have that ugly black dos window sat in the background.
Offline BanburyCo
Re: VAG COM
« Reply #13 on: 27 October 2010, 19:31 »
I'm sh!t at .vbs don't suppose you could share your file?
Re: VAG COM
« Reply #14 on: 28 October 2010, 10:39 »
pm your email addy :)
