Author Topic: Golf 3 GTI gearbox  (Read 4173 times)
Re: Golf 3 GTI gearbox
« Reply #10 on: 08 October 2010, 00:13 »
So? What about Dual clutch transmission
Again major work.
So what?
The verdict is that it's a very very expensive thing to do, and it's something that unless you are looking to get into competition, it's not really worth doing.
Yep spot on.
Offline Ess_Three
« Reply #11 on: 08 October 2010, 08:43 »
Fitting DSG?
VW 'tall block' DSG will physically fit...if you are lucky and make new mounts. But, they are big and heavy!
Then you need the controllers...which are CAN-Bus.
The Mk3 is not. So you need to change the Mk3 to CAN-Bus electrics...including the steering wheel and column, to get the 'paddles' (sadly, nothing more than feel-free micro switches) and accelerator pedal...you'd also need the Mk4/5/6 engine and DBW system if you wanted rev-matching/rev blipping.
And then you end up with a gearbox that does what it wants anyway, not exactly what you want, as a proper H pattern manual, or sequential 'box proper.
Maybe the newer Polo/Ibiza/Fabia dty clutch 7 speed DSGs would be better/easier...as they are lighter, less complicated and the lesser torque capability is less of an issue for your average Mk3...but I don't know if they fit 'tall block' engines.
Is the 1.2TSI/1.4TSI Twincharged a 'short block' or 'tall block' derived engine?
I don't know.
Mother is collecting a 1.2 TSI DSG Fabia in the next couple of weeks...so I'll have the chance to try it, and see if it's any 'better' than the larger wet clutch 6 speed DSGs. Unlikely, sadly...
..but gaining motorcycles.
Offline Stirring Moose
« Reply #12 on: 09 October 2010, 11:32 »
Well a mate of mine bought a brand new Hewland sequential 6 speed transaxle to go in the back of his Cavalier Coupe (long story, it's more a Cavalier shaped box to contain a lot of very trick bits!) and I know that came in at £5k - £6k. They probably do a similar unit for transverse set ups - touring cars and the like - but I doubt it would be any cheaper.
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
