Author Topic: oil temp sender?  (Read 3491 times)
Re: oil temp sender?
« Reply #10 on: 18 October 2010, 10:34 »
take the pressure sensor off again and read the markings on the spanner flats, there are 0.3bar and 1.8bar versions make sure you have the right one. as ben says check where you fitted it too, the 1.8bar one goes on filter housign 0.3bar on side of head.
buzzer is controlled by 1.8bar switch, with a yellow wire. the most common vdo pressure sensor is the 0.3bar one, so if you had a 0.3bar one and fitted that in the filter housing with a yellow wire then that would explain your problem
Offline madmanluke
« Reply #11 on: 18 October 2010, 18:30 »
thanks jonny. I sorted it in the end as you may already know as per E38!
thanks any way!
Offline Ben Lessani
« Reply #12 on: 18 October 2010, 18:40 »
thanks any way!
Not going to post the solution for other readers?
« Reply #13 on: 19 October 2010, 10:38 »
he had wrong wire to the sensor, was 0.3bar switch pressure sensor and had fitted the high pressure wire to it. you was on ze moneys :)
