Author Topic: ecu relay  (Read 886 times)
Offline mk3dan
  • low and for show
ecu relay
« on: 02 October 2010, 16:37 »
hi all wheres the best place to get one of the above relays and how much are they
thanks dan
Offline sharki786
  • GOT BOOST??
Re: ecu relay
« Reply #1 on: 02 October 2010, 16:56 »
dealers or a vw specialist and they about under £15 from dealers
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline mk3dan
  • low and for show
Re: ecu relay
« Reply #2 on: 02 October 2010, 16:57 »
thanks do theses relays fail often if so ill buy a couple
Offline boneybradley
  • Back in a Mk3...
Re: ecu relay
« Reply #3 on: 03 October 2010, 00:13 »
the original spec "far eastern" vw being cheap skates crap fail fairly often!! dealer replacement ones should be much better quality and german made
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: ecu relay
« Reply #4 on: 03 October 2010, 12:09 »
Dealer will give you a Grey/white one, that's the good one.   It was actually a PUD Recall when they are under warrantee and a few years after causing trouble starting usually sometimes cutting out.
If you get a new one, that should do the job,  no point wasting money on two, something else would fail needing replacement before the new one will fail again.  :grin:
£12.50 from dealer is what i paid.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
