Author Topic: You have my sympathy.  (Read 9159 times)
Offline Khare
  • The bear that khares
Re: You have my sympathy.
« Reply #10 on: 01 October 2010, 14:05 »
B, final answer  :laugh: :laugh: :laugh:
And yeah I do wish I had a mk2 again
NAAAAAAAAAAAAT  :tongue:
Offline dubber36
« Reply #11 on: 01 October 2010, 14:21 »
It's not just Mk2's my 2004 Passat steams up when it gets cold outside.
The servo that operates the fresh/recirc air flap on the heater inlet is shagged. When it's below 4 degrees, the air con dosn't work so will not dehumidify the air so the windows steam up. VW want 90 odd quid for the part, but reckon it's a dash out job to fix it. I don't fancy that, so have to put up with the rear windows dropped a few mm.
The one time that I did drive my Mk2 in the rain it was fine. Maybe I should start using that instead.
Offline Horney
« Reply #12 on: 01 October 2010, 14:23 »
My Polo is shafted on this front. It struggles to even demist the windscreen.
Nick
Offline gibby
« Reply #13 on: 01 October 2010, 16:21 »
To all the fellow MK2 owners out there. My thoughts are with you as the rain comes down in bucketloads. Its around this time of year that the joy of MK2 ownership starts to wain.
Time to get the sponge out.
What nonsense. Most of the mk2 guys on here will have read this thread by now and have no leaks. :grin: http://www.golfgtiforum.co.uk/index.php?topic=70858.0 :afro:
......now officially dubless.
Offline clipperjay
« Reply #14 on: 01 October 2010, 16:49 »
To date have water in rear drivers side expect the seal to be shot clusters aren't cracked.
Some moisture in the passenger foot well. Seal gone on the air vent on firewall I expect?
some drips near fuse box. Not sure sunroof drain hole is clean so is the corner firewall hole could be the bonnet lifter rubber seal will check that one!
Offline mwep201081
« Reply #15 on: 01 October 2010, 17:15 »
I sorted all my leaks but just dropped a large KFC Pepsi in the passenger footwell....
Dunno whether to get the sponge out or a straw??
Offline Sam
  • Sam I am
« Reply #16 on: 01 October 2010, 18:37 »
straw straw straw
Offline beechymonza
  • mad beech
« Reply #17 on: 01 October 2010, 19:19 »
I have a 2 door mk2 gti, Footwell behind passenger seat gets soaked , Plus seatbelt gets soaked, Whats causin this,,
No guts No glory,
Offline Khare
« Reply #18 on: 01 October 2010, 19:37 »
Probably sunroof.
Offline Mitching
« Reply #19 on: 01 October 2010, 19:41 »
Mines fine *touchwood*
The only thing I get when it's been raining is water from the roof gushing down the windscreen when I break  :rolleyes:
