Author Topic: Change Cam followers with CAM upgrade????????  (Read 4241 times)
Offline clipperjay
Re: Change Cam followers with CAM upgrade????????
« Reply #10 on: 30 September 2010, 19:32 »
well ill do the followers as not to bad for price.
as for the remapping ecu anyone know what the ones on ebay are like? there prob just the basic remap programmed to a spider chip?
I don't like the way they overfuel your car, how can a generic mapp give you better performance?
Not every car is the same nor mods so they play it safe, but its your risk after all if you go too lean on a rough mapp? I don't like static rolling road mapps either as they put a hair dryer on your intercooler for oxygen flow :wink:
You can spend £80 for an hour on the rollers to tune up or £350 to £500 on an actual road test (EPROM) on how YOU drive and HOW your car performs with load?  :smiley: or buy a chip of Egay for £50 if you go for that, let me know how your MPG goes  :grin:
Offline Bigdunc
« Reply #11 on: 30 September 2010, 20:11 »
will look in to finding some local places that remap with rolling roads. but might be worth a try on the ebay chips plug one in for few hundred miles see what difference it makes, but like u said they wont be matched up with the car and its mods
Offline danny_p
« Reply #12 on: 30 September 2010, 23:39 »
ebay chips have a nasty habbit of being offset maps.
so rather than giveing your engine more fuel where it needs it it just gets x% more everywhere.
if it's 8v on digi were talking about they are a bit of a pain to map as you ether need to do a lot of trial and correction with dataloging and each go means swaping eproms over or you need an emulator to twerk the map on then burn the chip when it right. most places problaly won't have the required emulator anymore.
all the VW's have gone bar 1.
« Reply #13 on: 30 September 2010, 23:44 »
Have seen ebay chips cause damage due to the fact they tend to get the car to run in cold start mode all the time.
Offline weazgti
« Reply #14 on: 01 October 2010, 08:54 »
+1
know someone that has one lets just say he likes visiting the pumps.
Offline clipperjay
« Reply #15 on: 01 October 2010, 16:57 »
Good to see loads on here, with common sense  :cool:
Jay
Offline Khare
  • The bear that khares
« Reply #16 on: 01 October 2010, 19:02 »
Don't bother with off the shelf chips. A remap has to be matched to the mods you have, otherwise you risk running too lean/rich and causing damage. I've had a bad experience with a chip and it resulted in spending £80 on a new ECU, so if I was you I'd save my pennies and get a proper remap from R-tech, Revo and the like.
As for camshaft, what did you go for? I heard a myth that mk2 heads couldn't take too much lift as the lobes would interfere with the tappet seat. However I heard this myth for the mk3 heads and I ran a cam with 11.52" lift and it was no problem. Here is the fitting guide I did.
http://www.golfgtiforum.co.uk/index.php?topic=122349.0
Offline Bigdunc
« Reply #17 on: 03 October 2010, 11:28 »
Had it fitted and wow the car flys, as for idle its fine to be honest the mechanic who fitted it timed car by ear and to be honest i had my driver camed with a gti cam, and this runs much smoother
i fitted a Kent GS1H, Changed the cam followers and the cam belt + waterpump, had to get a dizzy from scrap yard last min as when timing it died, so rushed around on a sat afternoon to find new one which ant easy lol.
car idles between 1000-15000, i can take vid of car running so ppl can see how it idles with highlift cam if anyone intrested
Offline clipperjay
« Reply #18 on: 03 October 2010, 11:40 »
Yes mate that would be all good to see and hear!  :cool:
Jay
Offline Bigdunc
« Reply #19 on: 03 October 2010, 12:43 »
ill try get one sorted asap then ill do one on cold start, one think i noticed when driving it yesterday is when slowing down had a tiny bit of judder but not really noticable, does run smoother that i thought it would, the test will be sat in traffic tomorrow morning on way to work.
