Author Topic: Rear Electric Windows.  (Read 3110 times)
Offline mr wong
Re: Rear Electric Windows.
« Reply #10 on: 27 January 2005, 19:28 »
OK sorry about this lads, but being a novice, how do I get the door panel off :embarrassed:???
Also, going by the Haynes manual, thay rate this as quite a difficult job, will i be able to do it myself or do you reckon I should just pay a garage to fix them. Also both rear windows are not working again.
mrwotto
« Reply #11 on: 27 January 2005, 19:49 »
To remove the rear dor, you need to remove the trim around the switches, then undo the screw/s, not sure if there is one or two cant remembe lol.  Next remove the door lock pin from the top.
Then the door is just clipped in, so carefully remove the door panel, now you will need to remove the soundproofing, best just to cut it away with a sharp knive, but not to much so it can be taped back up again.
Now you will have access to the motors etc.
Hope this helps
Paul
