Author Topic: dial swap  (Read 2802 times)
Offline jp123
Re: dial swap
« Reply #10 on: 27 September 2010, 18:00 »
ill probably end up just getting em of ebay cause theyre can be cheap
Offline weazgti
Re: dial swap
« Reply #11 on: 28 September 2010, 18:18 »
Got the remains of a driver set here, they have a rev counter and they are single plug ones.
Offline jp123
Re: dial swap
« Reply #12 on: 29 September 2010, 00:01 »
when you say remains?
Offline weazgti
Re: dial swap
« Reply #13 on: 29 September 2010, 18:42 »
no bulbs or speedo but could be made to work. The rev counter works on it.
Offline jp123
Re: dial swap
« Reply #14 on: 03 October 2010, 09:50 »
so i could just pop my speedo into these, that was the plan anyway as i want to keep the mileage, anybody give me an idea how hard it would be to replace all the bulbs?
Re: dial swap
« Reply #15 on: 04 October 2010, 11:57 »
bolbs just fit in the back, twist to lock em in place. speedo should just swap over
Offline jp123
Re: dial swap
« Reply #16 on: 05 October 2010, 15:05 »
Right iv found a set in a scrappy, but before theyre removed from the car is there a way to tell if they are single plug to save me some time if theyre not, its a H reg but i cant tell via were the hazards switch is because theres no steering wheel column and the dash buttons have mostly been removed, is there any other way to check?
Offline Simeon
Re: dial swap
« Reply #17 on: 05 October 2010, 21:40 »
H reg will be single plug so fine for your late spec car :)
Re: dial swap
« Reply #18 on: 08 October 2010, 14:43 »
take dash undertray off and you can see bottom of plugs, also check the header tank if its round then they're 1 plug clocks
