Author Topic: 2.0 ABF with Megajiz - Talk to me  (Read 14282 times)
Offline Ess_Three
Re: 2.0 ABF with Megajiz - Talk to me
« Reply #20 on: 22 September 2010, 23:31 »
You want high-output circa 200bhp.
I can show you an ABF delivering +170bhp on OEM management with a good exhaust manifold and a few tweaks, but I can't show you a 100bhp/l output motor on Digifant 3.2.
I can show you a 190+ BHP ABF on Digi 3.2...but it'll not go over 200.
Oh, and it's on a standard (modified) manifold.downpipes too...and runs a cat/passes the MOT on emissions.
As has been said before, big cams + Digi 3.2 = problems...
I can add a 268 ex cam and break 200 BHP..but it'll not idle, it's useless below 4000 RPM and it's 15lb-ft doen on the 268/std cam set everywhere...for a loss of 5 BHP. I know which is faster out on the road.
Quote
For that you'll need ITBs and some pokey management, as well as cams and head-work.
Yup...
..but gaining motorcycles.
Offline Ess_Three
« Reply #21 on: 22 September 2010, 23:34 »
Mine was 197 @ fly, 175ish at wheels.
Chewed up and spat out VR's.
Yer i know mine looses 39bhp through gearing and such like
Mine makes about 140-143 ATW...for 190-197 BHP @ flywheel, on a MAHA dyno.
There is no way you'll make 200WHP on a NA ABF with a budget less than the cost of a Lehmann motor or similar!
I have around 50 BHP losses, for a set of 16v ratios, LSD, lots of negative camber and lots of toe out.
Offline Ess_Three
« Reply #22 on: 22 September 2010, 23:41 »
If the number '200' is an absolute must...then you're looking at £4000-5000 easily to go there.
If you want it to go like a 200BHP ABF engine/box would, go to 170-180BHP which is fairly cheap, fit a light flywheel, and change the FD on the 16v 'box...a 7300RPM revving 180 BHP ABF on a light flywheel and 3.94 or 4.2 FD, with a good ATB/LSD will be a good set up.
I've just removed a O2A 16v 'box c/w Quaife diff and 4.2 FD and a ligh flywheel to go the next step up...but the last set up was very nice...I'm unsure if the 4.2 was amybe a bit much...maybe the 3.94 I had in before was the better 'road' 'box...but it really sings on a 4.2.
Probably too low for a Mk2 on 15" wheels though...
Offline Sam
  • Sam I am
« Reply #23 on: 23 September 2010, 08:45 »
This is possibly the most interesting thread we have had in the section for a while (to me at least) and it hasnt broke into an argument. Gonna scrap the ABF Megajiz option then, sound like alot of fvcking about with little gain. I think you could turbo a car for 2k with a bit of nouse so will probs stick with turbos and superchargers, playing with them at the tender age of 20 (  :grin: ) should set me up pretty good for the future. Cheers guys!  :kiss:
Offline Agreeable Slick
  • Unit
« Reply #24 on: 23 September 2010, 08:47 »
Balls, forgot to check my paperwork. I did however stumble across a RR print out.
I got the figures arse about face, was 157 @ wheels not 175. (thought that sounded a bit high when I typed it) my bad.  :embarassed:
Another consideration is that as you lighten everything, your torque will also drop off a lot more, as you are ridding the car of rotating inertia and mass, so it's a fine line of getting the balance right in order to benefit in both power and torque.
Offline Sam
  • Sam I am
« Reply #25 on: 23 September 2010, 08:55 »
Yer have just been looking into lightening my flywheel but i figured it would lead to heavy turbo lag when accelerating up hill. I got a little distracted by carbon fibre prop shafts too  :evil:
Offline Ess_Three
« Reply #26 on: 23 September 2010, 08:55 »
For £2k you can drop a BAM/AMK 1.8T in, that was designed to be turbo'd, add a custom map and a decent FMIC have a 265 BHP engine (breaking the 200 BHP @ wheels) and if mapped well, be perfectle drivable without mental wheelspin.
I'd not even think about turboing an ABF when you can drop in a complete set-up that's plug and play as near as dammit.
But then you'd never build a high revving ABF if you wanted big power numbers.
Offline Ess_Three
« Reply #27 on: 23 September 2010, 08:58 »
A lightened flywheel wouldn't add any more lag....if anything it will help the engine get on boost quicker as it'll rev up quicker.
The flywheel still has weight...just less weight.
Midrange/peak torque is not affected...sure it may idle slightly lumpier (mine doesn't) and it may be easier to stall (true) but none of my other numbers changed...it just revs quicker.
Offline Sam
  • Sam I am
« Reply #28 on: 23 September 2010, 09:00 »
That was just after a quick gander, from what i gather a weighty fly has momentum but takes more effort to get it there and a lightend fly has less but takes less effort, I figured seen as it hasnt been done on my car before there is a reason for it, cos it seems like a fairly obvious/easy thing to do
Offline Ess_Three
« Reply #29 on: 23 September 2010, 09:03 »
I don't get it either...
You can spend £2000-3000 adding 30 BHP...or you can change the flywheel and get what feels like the same gain, out on the road.
...and a lightened flywheel will cost you approx £100 + fitting.
There is probably less of a gain on an O2O flywheel compared to an O2A flywheel as they are smaller to start with (O2O that is).
