Author Topic: Wheel Nut Tightening  (Read 2319 times)
Offline Tazzy
« on: 17 September 2010, 20:48 »
this might seem im being a bit anal
but earlier today as the driver and i broke down twice in the work truck because of a dodgy rim, as it was fixed (twice) the mobile tyre fitter torqued up the nuts
common sense obviously
with all my cars, ive just tightened them till i cant tighten them anymore, but with the golf i want to do things properly
so does anyone know what pounds of torque pressure i need to tighten up the wheel nuts?
cheers
« Last Edit: 17 September 2010, 20:54 by Tazzy »
If It Comes Off, Modify It!
Re: Wheel Nut Tightening
« Reply #1 on: 17 September 2010, 21:31 »
110nm is always what I have done mine up to or check the manual.
Offline AlexMozza
« Reply #2 on: 17 September 2010, 21:38 »
I go with the whole 'It wont go on any more' idea, but 110nm sounds about right :D
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline Ben Lessani
« Reply #3 on: 18 September 2010, 13:25 »
110nm is fine, but that is a dry torque figure.
If you've got copper slip on the bolts - I genuinely have no idea, some say torque less, some say torque more. I put copperslip on my bolts and just stick to factory torque figures and check regularly.
« Last Edit: 18 September 2010, 13:27 by Ben Lessani »
Offline Tazzy
« Reply #4 on: 23 September 2010, 09:04 »
on a completely different note, but as i did start this thread, saves me making a new one...
i need to know the shade of silver my car is, any ideas?
mk4 golf gti, 1.8 20v, T-reg
cheers
Offline Benrevs
« Reply #5 on: 27 September 2010, 12:36 »
Most likely Reflex Silver. The actual code is under the carpet on the boot floor.
