Author Topic: under steer  (Read 5962 times)
Offline musicman87
Re: under steer
« Reply #10 on: 12 September 2010, 22:28 »
Also with FWD the ARB should be stiffer than the rear to reduce understeer. However, increasing stiffness at the front can increase the possibility of snap oversteer from the back end. Just look at Stig when on the last corner of the MKV GTI's lap (search you tube) and then imagine having a car that is set up to possibly do that easier!!!!
Ultimately the best way of increasing cornering ability is to fit adjustable top mounts, so you can increase negative camber, which will give you better cornering ability, but will also make the car LESS stable at high speed (100mph+).
acenumber1 - Pay attention to this man - he's been there, done that and has done far far more than just bought the t-shirt (his MK5 GTI ED30 embarrassed a few Porkers at the ring a few times, sure he'll post the video link if you ask nicely!)
55' Tornado Red 3-Door GTI, Manual, 17" Monza's, Totally original!
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: under steer
« Reply #11 on: 12 September 2010, 23:06 »
He may have been there, but hes giving incorrect information.
hes saying a softer rear arb reduces understeer. it doesnt, it increases it.
to reduce understeer / increase oversteer, you want a stiffer rear setup.
Offline AlanD
  • MK5 2.0T 16v
Re: under steer
« Reply #12 on: 13 September 2010, 09:37 »
What tyres have you got at the moment?
I dont think I've EVER seen a thread in the MK5 section about understeer ! :shocked:
Offline tuscan_thunder
Re: under steer
« Reply #13 on: 13 September 2010, 12:00 »
first off: good tyres. I like Eagle F1s, amazing in the wet.  Better than Michelin PS2s, not sure how they compare with PS3s or the Contis
(my wife's Saab has the Contis and they're good but the F1s feel better - might be just as it's different cars).
second, try the anti-lift kit.
The stiffer the rear, the better the turn in will be - my hillclimb car is basically rock solid at the back (it's torsion bar but equating to 600lb/inch springing.....) and, despite being FWD, wants to oversteer quite a lot.....
Not just au fait with MK5 tuning so unsure if this is possible, but any kid of strut brace on the rear is a good idea.
Look at adjusting the front toe - minimise the toe-in as this will lead to a better/faster turn in.  It'll make the car less stable in a straight line and will make it tramline more but, as ever, it's a compromise.  Toe-out is maybe a little extreme on the GTi.
Maybe a little cheeky on a forum but I suspect your driving could do with a brush up too - not saying mine couldn't either, I think we can all benefit from good training.   Bear in mind even current F1 drivers still get coaching.
Offline Horney
Re: under steer
« Reply #14 on: 13 September 2010, 12:26 »
You see the thing on the end of your right leg? It pokes out a bit and has 5 little wiggly things on the end. Don't prod the right peddle so hard with this and your problems should be solved.
Nick
Offline Komenda
Re: under steer
« Reply #15 on: 13 September 2010, 12:33 »
If anything Mk5's are prone to oversteer under load. Before you do anything to the car, I'd get out on track with an instructor and learn about weight transfer.
Most road drivers in FWD cars are still heavy on the brakes coming in to a corner, pushing all the weight on to the loaded tyre causing understeer. It's important to stabilise the car and equalise the weight.
2 simple rules to follow: If you understeer in to the corner, you are too fast and broke to late. If you're understeering out of a corner, then you're on the throttle too early.
Offline musicman87
Re: under steer
« Reply #16 on: 13 September 2010, 12:51 »
He's got a point - it goes without saying that different cars need a different approach to driving and the way to tackle corners and it's probably fair to say that a remap on a GTI, increasing power by approx 20-25% (maybe more depending on stage of remap) will change the dynamics enough to require a different driving style (This is the subject where the guys who have done track work will confirm). I don't know what car you have come from but I could pretty much guarantee it requires a different approach to the GTI
I've found that by trying different approaches with my GTI, the "Slow-in, Fast-out" approach works best. Slightly slower into the corner, get on the power early to let the turbo fill it's lungs and it should rip you out of the corner! (as long as your in the right gear of course!)
This is different to my previous car (Fiat Panda 100HP) that had Eagle F1's as standard,
and (on that car i thought they were absolutely rubbish in the wet) you could just chuck it in, get it off balance and nail the throttle all the way through, it had that little power that any way you could maintain the momentum had to be done!
Try all of the above and find what works best for you, I don't think the guys above are criticising your driving as such, just trying to help you learn the car as getting used to a new car takes a little bit of time, especially if you've never experienced a turbo'd engines power delivery before!
Is this really true of a FWD car? I thought FWD cars would under-steer under load due to being dragged through the bend? I thought that over-steer would be caused by either trailbraking too fast to cause it to go off balance of again, lifting off the the throttle part way through the bend would again get the car off balance and cause the back to slide wide!
Correct me if im wrong!
Offline Komenda
Re: under steer
« Reply #17 on: 13 September 2010, 13:01 »
It is throttle induced, but happens without much warning. I quite liked it as it was a good way of pulling the nose in, in a quick corner
« Last Edit: 13 September 2010, 13:03 by Komenda »
Offline Keano
Re: under steer
« Reply #18 on: 13 September 2010, 13:18 »
Never realised how badly i drove until i drove round Silverstone under an instructor. ( i always thought i was the world's best too!  :undecided: )
I'd deffinatley reccommend it bud.
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
Re: under steer
« Reply #19 on: 13 September 2010, 15:55 »
As above some professional instruction will be more beneficial than of any tyres / performance mods.
Also, why do you guys buy the WALK when you can just fit powerflex poly bushes in the OEM mounts (which AFAIK) are OEM that have been anodised gold?
