Author Topic: Rhyso's 205bhp Posh Golf....Gone :(  (Read 670748 times)
Offline Rhyso
Re: Rhyso's Posh Golf
« Reply #720 on: 25 June 2011, 21:32 »
May be worth looking into another group buy tech  :wink: :grin:
Good luck with that one  :laugh: :laugh: :laugh:
Offline mowlamb
  • MK4 GT TDI 130 - DERV POWER!!
« Reply #721 on: 25 June 2011, 21:54 »
Hence why I suggested tech tried it  :wink: :wink:
Offline dom
  • Back in a Mk4
« Reply #722 on: 25 June 2011, 23:17 »
Why do you want the fogs to deactivate when you indicate?
Wind deflectors look good btw :cool:
« Reply #723 on: 26 June 2011, 00:07 »
I would guess so you can see the indicator more clearer.  :smiley:
Offline Rhyso
« Reply #724 on: 26 June 2011, 19:28 »
Fogs are in the lower grill so if you can't see the indicator you shouldn't be driving  :grin: :grin:
Offline SoundillusioN
« Reply #725 on: 27 June 2011, 11:47 »
 :grin:
Wasn't the original question about having the function where the fog comes on when indicating/turning?
Offline Rhyso
« Reply #726 on: 27 June 2011, 11:52 »
 :grin:
Fogs are now running as DRL's; the option I've ticked turns off the DRL when indicating  :nerd:
Brucie bonus is they also work as fogs as normal when I set the switch to the correct position  :smug:  If used as normal then the fogs remain on when indicating
Only thing I've got to work out is why one side appears brighter than the other  :undecided:
Offline AlanD
  • MK5 2.0T 16v
« Reply #727 on: 27 June 2011, 14:26 »
Are the bulbs easy to swap around on the fogs?
Offline Rhyso
« Reply #728 on: 27 June 2011, 14:32 »
Yeah I've already fitted an uprated set of bulbs back last year  :smiley:  Not sure if when re-fitting the bumper last week the position of one of them is slightly out  :undecided:  Although when used as normal fogs the brightness appears to be uniform  :huh:
I'll have another play round tonight  :smiley:
Will also get pics of the number plate surround which is being wrapped as I type this
Offline Rhyso
« Reply #729 on: 27 June 2011, 17:20 »
Thanks again to Kris (Fabla) :afro:
The cutouts around the holes are because he wasn't sure which ones I used to secure the number plate to the holder  :grin:
Fitting takes place in about 6 minutes as I'll have finished work then  :laugh:
« Last Edit: 27 June 2011, 17:24 by Rhyso »
