Author Topic: Rhyso's 205bhp Posh Golf....Gone :(  (Read 670062 times)
Offline Bellend
Re: Rhyso's 205bhp Posh Golf....3 years of ownership
« Reply #1410 on: 13 March 2014, 22:28 »
Somehow knocked a sensor? Does it do it under light acceleration? Normally a wheel sensor slightly pulled out or the steering wheel LAT sensor out.
Where all my moneys went.
Offline Rhyso
« Reply #1411 on: 14 March 2014, 08:11 »
Sensors all look to be in place.
Depends on steering angle really although it did it in an almost straight line last night whilst changing from 3rd to 4th at about 50mph  :undecided:
Tread is evenly matched on both sides. I had 4 wheel alignment done at the time and everything was spot on. It had was virtually identical to the last alignment check 12 months ago
Going to check the pressures in a bit
Offline Rhyso
« Reply #1412 on: 14 March 2014, 09:22 »
Pressures are fine  :undecided:
What was unnerving was a put it into a bend i know i can comfortably take at 50mph+....as soon as i hit 35/40 the front left began breaking. I changed direction to go left and it then braked the right front. I had no throttle applied  :undecided:
Offline Bellend
« Reply #1413 on: 14 March 2014, 15:03 »
Time to get an oscilloscope on the sensors.
Offline topher
  • Administrator
  • fully functioning
« Reply #1414 on: 14 March 2014, 19:35 »
no need for a scope, vagcom abs measuring block 001. Give me a shout when you've got the laptop hooked up Rhys i'll talk you through what to look for.. can't be arsed typing it all out :grin:
Offline Bellend
« Reply #1415 on: 14 March 2014, 19:38 »
The amount of time that would have saved me in the past. :grin:
Offline Rhyso
« Reply #1416 on: 14 March 2014, 19:42 »
You got my text then??
Hooked up VAGCOM earlier so noted the measuring blocks. I suspect its the left front ABS sensor thats taken a knock  :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #1417 on: 14 March 2014, 20:03 »
no dude not had a text from you?
Offline Rhyso
« Reply #1418 on: 14 March 2014, 21:29 »
Hmm you changed your number then?.  :huh:
Offline JC
  • Back in the North.
« Reply #1419 on: 15 March 2014, 03:35 »
 :laugh:
