Author Topic: steering lock  (Read 882 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
steering lock
« on: 09 September 2010, 19:38 »
right my steering lock is stuck on but the car still fires up
i have managed to get a spare column with everything on
i need to change the ignition switch at the same time
so i thought i would change the one part all at once with the ignition switch fitted
steering lock and ignition barrel as it looks like it seperates from the column
i got those aukward bolts off after a hammer and chisel job
everything is loose but how do i remove it from the column itself
i need it all swapped over for saturday
thanks
rob
