Author Topic: Late 90's Audi A4 2.5 V6 TDIs. Anygood?  (Read 4885 times)
Offline Horney
Re: Late 90's Audi A4 2.5 V6 TDIs. Anygood?
« Reply #20 on: 08 September 2010, 21:44 »
Tried one a while back. Didn't rate it against the PD 130. Felt free-er revving but lacking grunt.
PD 130 Passats command much more money which is the issue. I'll have to take a few out and see what they're like before I decide though.
nick
Offline JC
  • Back in the North.
« Reply #21 on: 08 September 2010, 22:36 »
the call of the Wagon is Strong  :grin: :laugh:
just wish i could find a decent wone with les that 200k on it  :shocked: :cry:
Offline filthy
« Reply #22 on: 09 September 2010, 09:12 »
I just bought a Passat 1.9 TDi...same engine as the A4 (AFN 110bhp)....great engine...torquey and economical....
Also, Passat estates are cheaper than the A4s....worth a look!
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline Organisys
  • Old and Slow...
« Reply #23 on: 09 September 2010, 12:05 »
^^^ and slightly larger I think.
« Reply #24 on: 11 September 2010, 20:05 »
I own a B5 '97 A4 as you know. The build quality is very good.
The 2.5tdi is an older engine, bit more unrefined and noisey compared to a 1.9tdi. Not that economical either.
I'd look for a 1.9tdi. Mind you these cost more, especially clean ones with low miles.
 :smiley:
How can the 2.5 V6 be an older engine when it come out laterĀ  :undecided:
Offline filthy
« Reply #25 on: 13 September 2010, 22:52 »
I was out in the brother in laws A4 Avant yesterday, and yes, the Passat IS bigger.... :smiley:
Offline Organisys
  • Old and Slow...
« Reply #26 on: 14 September 2010, 12:43 »
 :smiley:
How can the 2.5 V6 be an older engine when it come out later  :undecided:
Seems you are right, I thought the C4 had the same engine, but I see that was an inline 5 not a V6 !
Offline shedpainter
« Reply #27 on: 16 September 2010, 09:00 »
About four years ago I owned a 1998 Audi A6 2.5 V6 Tdi 150ps with 130k miles on the clock; this is presumably the same engine fitted to the A4 that you are interested in.
Common problem with these is gearbox pinion wear (after about 100k miles) that causes a slight high-pitched whine on over-run (mine had it but it never caused a problem). Big job to fix but the gearbox could continue to run 'forever' with the problem.
My A6 leaked oil from sump. Not a straightforward case of changing the sump gasket - not likely! The V6 has a 'split sump' that requires removal of the oil pump (amongst other things) to replace the gasket(s).
Apart from that it was a nice drive, went like a rocket and produced very reasonable MPG when plodding along.
I'd have another (much newer) one if given the choice.
Hope this helps.
Cheers - Shedpainter
