Author Topic: XENONS - Q & A retrofitting & functionality  (Read 507407 times)
Offline The Doc
  • E63s Estate - Vito Sport
Re: People With Xenons
« Reply #370 on: 21 January 2011, 18:40 »
Nice codes Steve, well found :-)
Offline Jimble
« Reply #371 on: 21 January 2011, 18:55 »
Dead easy mate, you'll have no problems. :wink:
Thanks.
I feel that Xenons are now crucial due to the sad state of our potholed roads as they will provide much better lighting for one to see their ever increasing numbers. My next car will def be specced with these from the factory.
For the time being, and urgently, I'll order the Osrams to provide me more light. It really has become quite a problem as the standard Halogens are worse than useless IMO.
Did you buy yours on-line?
Yes mate, got them from powerbulbs and used the forum discount! Only ordered these in particular as they were named the best buy by auto express. :wink:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #372 on: 21 January 2011, 20:36 »
Quote
LED daytime running lights work on the new Golf 6 ab 45 / 2009 or bcm 1K0937087D or higher and a minimum program SW0575
all it takes to run (for those which you have the original xenon lights)
byte 11/bit2 deactivation daytime lights
byte 15/bit3 activation - part of the reduction of intensity at the flashing indicators
byte 15/bit6 activation
byte 15/bit7 activation
18 byte / value 04
byte 24/bit7 activated LED daytime running lights
byte 25 /% intensity daytime running lights
byte 26/bit2 activate
byte 27/bit2 activate
this coding could not do so coding has already been used on a golf 6, for me will come when the new lights to me.
that's it
As soon as someone tests this and confirms it for RHD UK models we will put it in the tech section. :smiley:
Current Garage:
35+ years of GTI ownership.
Offline SteveP
« Reply #373 on: 21 January 2011, 20:59 »
^^^ I will confirm tomorrow  :smiley:
I have a slightly different set of coding options but the main bits are the same.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #374 on: 21 January 2011, 21:04 »
Thanks. Is the wiring different too?
Current Garage:
Offline SteveP
« Reply #375 on: 21 January 2011, 21:07 »
Nope
Offline Belix
« Reply #376 on: 22 January 2011, 16:30 »
Was just tailed by a new GTi with LEDs I'm assuming factory fitted as it had no plates yet. Was through a tree lined road, and noticed that when in sunlight, only LEDs on, but when in a dark patch, LEDs dimmed to about half brightness, xenon's came on.
Offline SteveP
« Reply #377 on: 22 January 2011, 20:11 »
Let there be light  :cool:
Offline am1w
« Reply #378 on: 22 January 2011, 20:17 »
...and there was light.
Lots of it. Congrats.
Offline Belix
« Reply #379 on: 22 January 2011, 20:19 »
All go smoothly, or hit some bumps in the road? Do they work as described above?
