Author Topic: ABS Light  (Read 2165 times)
Offline kr1s77
ABS Light
« on: 19 January 2005, 18:29 »
The other day my ABS light came on and stayed on. That means i need to change my brake pads right?? I know the front have sensors, but do the rear ones have sensors aswel?? Any idea how much the pads will be about?? Will the light automatically go off when the pads are changed or do i have to get the machine to reset it??
Thanks
P.S.
my golf is gti 2.0 8v 1997
ASV 1.9 TDI 110
Offline audiquattro
Re: ABS Light
« Reply #1 on: 19 January 2005, 18:51 »
ABS light has nothing to do with brake pads i'm afraid, there is a separate light for that.
Most likely you have a problem with one of the ABS sensors or rotors.
Offline kr1s77
Re: ABS Light
« Reply #2 on: 31 January 2005, 21:41 »
I Got my mate to put it on his Machine. It said the rear left speed sensor was gone. GSF said they have them ?39 + vat. Gonna have a go tomorrow
ASV 1.9 TDI 110
Offline adyh
Re: ABS Light
« Reply #3 on: 01 February 2005, 12:39 »
Be carefull with the GSF ones , i bought one and had to sand it down to get it to fit .
Offline AudiA8Quattro
Re: ABS Light
« Reply #4 on: 01 February 2005, 13:44 »
I wouldn't buy ANYTHING from GSF.
If you want good parts and not pay dealer prices, go to EURO CAR PARTS.
Offline kr1s77
Re: ABS Light
« Reply #5 on: 06 February 2005, 17:03 »
really, i think GSF are ok, i had problems with ECP before. Anyway i changed the sensor and the light came off, so everything? is back to normal. :smiley:
ASV 1.9 TDI 110
Offline Dave_GTI16v
  • 'Guns N' Roses'
Re: ABS Light
« Reply #6 on: 06 February 2005, 23:28 »
i have the same problem but mine isnt always on, where abouts is the sensor? can u get to it without taking wheels off?
MK3 GTI 16V '95'
''its better to regret something u did, than something u didnt do''
Offline kr1s77
Re: ABS Light
« Reply #7 on: 07 February 2005, 06:45 »
At first mine used to flicker on & off, then it stayed on. I had to change the rear left. it's behind the brake disk & held on with an alan key bolt (on the rear ones, not sure about the front ones), so yes you will have to take the wheel off. I had a guy put it on a diagnostic machine to see which sensor had gone. it was easy enough to do, i just followed what it said in the Haynes manual
ASV 1.9 TDI 110
