Author Topic: Mk4 rear wiper problem  (Read 2495 times)
Offline Cov golf
« on: 02 September 2010, 12:53 »
Hello to the people that take the time out to read this my problem is it dosent work I pull the stork to the on position and if I hold it there no water comes out of the jet ether do you think it's  the motor fu#ked or something els like a fuse gone cheers for any reply
Adam
Offline smartie78
Re: Mk4 rear wiper problem
« Reply #1 on: 05 September 2010, 18:58 »
water flows through motor and are quite common to fail internally in the motor.this causes water to run out inside tailgate trim and causes corrosion of terminals at multi plugs at motor and boot latch.remove trim and check hose at motor and all wiring for corrosion damage]
Offline Cov golf
« Reply #2 on: 05 September 2010, 19:08 »
Cheers for the advice mate how do you get the tail gate of I unscrewed the black screws in the hand holes tryed to pull it of it didn't move didn't want to just rag it off incase I broke it any tips for getting it of would be good
Offline smartie78
« Reply #3 on: 05 September 2010, 19:13 »
[/clips are quite tight.a plastic trim tool inserted in at corner near grab handle at corner and prise till clip pops.same at other corner.then you will see inside where other clips are.can also use plain screwdriver to prise corners but watch for scratches to tailgate.]
Offline Cov golf
« Reply #4 on: 05 September 2010, 20:16 »
Cool cheers mate il give it a go
