The member Jonnyturbo had major turbo lag issues. A 5 min health check of the actuator found the wastegate was bleeding the exhaust gasses off which caused the lag. Then a 5 min job to reset the actuator. And now the turbo is spooling as it should and the car fliping pulls like a monster. Now running stage2 spec and 230bhp with a really wide torque band.
From day one Jonnies car has had issues, from being down on power running the stock map with a handful of fault codes, to running the spec1 remap with a N249 fault and having turbo lag and boost issues. But he has followed everything I have told him and took my advice, very little money spent getting the car running 110% maybe £180 max on parts then just his time. No need to spend a ton on fancy Forge pipes, just find out which is the faulty item and replace it with a new OEM part.
If you dont want to spend time trying to work the issues out or you dont want to take half a day out and drive to us, I will try and talk you through it step by step. It will be hard because you dont know how to use your Modis so I will give you all the things to test without the use of diagnostics tools
Job 1: PCV System
Take off boost side of PCV system off and check its working and not leaking.
Remove N249 / SAI plate from front of inlet
2 x 5mm allen bolt and 2 x 10mm nuts.
Remove main PCV pipe which connect to the nipple under the inlet manifold, pull green clip from crank breather tube, remove one way check valve from rubber housing. and pull the hole mess of pipes out and inspect on the bench. blow down the main pcv pipe which connected to the inlet and try to haer fro leaks ( I am 99.9% sure you will find a leak) Main issues in this area are,
1: one was valve not fully shutting and leaking boost, a new upgrade G revision from TPS will set you back £7.
2: Rubber pipes with hair line split in the innder bends
3: Black plastic bit which is part of the brake servo line leaking, again a new upgrade revision from TPS £30
Let me know how you get on here, then we will go to the next stage ect..
Nick.
