Author Topic: Tyre pressure sensor  (Read 9944 times)
Offline RickS
Re: Tyre pressure sensor
« Reply #10 on: 31 August 2010, 12:42 »
I wondered if they randomly go off as the tyre wears down so the radius is changing.
I'm just wondering what difference the tyre radius will make to the pressure?  :huh:
2012 R. Rising Blue 3 door DSG with 19" Talladega's, RNS510, Dynaudio, Cruise, DCC, Rear Cam, Colour MFD, Lux pack, Storage pack, Service plan.
Offline SteveP
« Reply #11 on: 31 August 2010, 13:58 »
^^^ The TPMS on UK cars works on the ABS sensors to detect changes in the rolling radius of the wheels.
Offline RickS
« Reply #12 on: 01 September 2010, 06:58 »
OK Steve, but how does the ABS system measure the rolling radius?
Offline Ess_Three
« Reply #13 on: 01 September 2010, 11:19 »
One revolution of a wheel gives x number of pulses detected by the ABS sensor...if all wheels give the same number of pulses per revolution when checked against the stored default (reset, once the pressures are set) then all tyres are at the same pressure...if one tyre goes flat, then it gives less pulses than the other 3 per revolution, or different value to the stored 'reset' value (over single or multiple revolutions, however the system measures it) it triggers the warning.
Same method for detecting wheelspin to activate XDS/traction control...same again for detecting locked wheels under braking etc.
Same principle again for launch control on aftermarket traction control systems or ECUs.
..but gaining motorcycles.
Offline RickS
« Reply #14 on: 01 September 2010, 12:22 »
Of course, should have realised that, DOH!. Being pedantic, just one small point, wouldn't a flat tyre give more pulses than the others due to the reduced radius? [More turns to go same distance]
« Last Edit: 01 September 2010, 12:25 by RickS »
Offline Ess_Three
« Reply #15 on: 01 September 2010, 12:52 »
Well spotted...yes, it would.
Difference in pulses being the key...once a pre-determined difference is met, it triggers the warning light and noise.
Offline ajmoir36
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline mfl
« Reply #17 on: 03 September 2010, 10:37 »
We have the same set-up on the Aus version cars as well. sometimes its operation is a little random, I have had the warning go off after a bit of wheel spin, checked the tyres pressures and all was fine. Other times its gone off, there was between 2 - 6psi difference in the tyres.
Offline H12
« Reply #18 on: 04 September 2010, 15:45 »
^ Was common on the mk5's too. I bet your dealer had not set it up  :wink:
Lol- it wouldn't surprise me !! Since I reset it, no more false alarms which is good but I did notice some very small stone chips on the 18" alloys when I checked the tyres... doh !! but can't say I'm that shocked juding by the state of the UK's roads  :sad:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #19 on: 04 September 2010, 16:44 »
:sad: :cry:
Little dab of lacquer on a cocktail stick to seal the hole, let it dry. Polish then jetseal109 them maybe some wax too.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
