Author Topic: hand break stuck :(  (Read 2570 times)
Offline mchugh
Re: hand break stuck :(
« Reply #10 on: 21 January 2005, 17:21 »
cheers for that will give it a try
Offline mchugh
« Reply #11 on: 23 January 2005, 16:30 »
fixed it :) used a load of wd40 sprayed it down the hand break cable sprayed a load on the caliper and then turned the nut where the hand break cable was in place and it just clicked and is working fine now... the wd4o on break prolly not great idea lol ill be sliding tho :p
Offline druid
« Reply #12 on: 24 January 2005, 14:34 »
A new hand brake cable is about ?7.
ive just been and got one from euro car parts.
The only trouble you may have is that if the handbrake gets stuck on then you will struggle to drive home with it.
so it may be worth the ?7 and an hour of your time to sort it.
cheers drew
