Author Topic: Fitted Golf R Lights But Having One Issue*Now Sorted  (Read 17636 times)
Offline mike.
Re: Fitted Golf R Lights But Having One Issue
« Reply #20 on: 30 August 2010, 10:01 »
Ess_Three I have created the table below from info I got on a German forum
According to them 0x44 is the coding for a Xenon equipped car with LED rears.
I was going to give this a go on countrytruckers car the next time he called up but haven't had a chance yet.
Maybe worth a go although the version of the CCM does seem to have different effects.
Quote
VW360 GTI Halogen "VW360 RdW TFL_0_LED + LED_SBBR"    Hex 04   Binary 0000 0100
Halogen, Rest Of World, LED DRLs, LED Rears
VW360 GTI Halogen "VW360 RdW TFL_0 +LED SBBR"       Hex 15   Binary 0001 0101
Halogen, Rest Of World, Bulb DRLs, LED Rears
VW360 XENON "VW360 RdW XE LED_SBBR"           Hex 44   Binary 0100 0100
Rest Of World, Xenon, LED Rears
« Last Edit: 30 August 2010, 14:02 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Ess_Three
« Reply #21 on: 30 August 2010, 10:19 »
Depending what garage you take your car too  :wink:
Perhaps so...but the fact is, it's illegal.
Whereas a car will pass an MOT with retro-fitted Xenons despite not having headlight washers/auto levelling (so long as the headlights are projector type and the beam pattern OK), it will not pass with no sidelights, or a cat removed.
Of course there are some dodgy MOT stations out there...
..but gaining motorcycles.
Offline Ess_Three
« Reply #22 on: 30 August 2010, 10:24 »
Quote
VW360 GTI Halogen "VW360 RdW TFL_0_LED + LED_SBBR"    04   0x04   0000 0100
VW360 GTI Halogen "VW360 RdW TFL_0 +LED SBBR"       21   0x15   0001 0101
VW360 XENON "VW360 RdW XE LED_SBBR"           68   0x44   0100 0100
Mike,
Is this the same long code as I changed the bit previously - the one suggested by Steve in his instructions?
I'll go have a play now if so.
Cheers,
Glen.
Offline mike.
« Reply #23 on: 30 August 2010, 10:30 »
Yes Glen, BYTE 18 in the Central Electric Controller.
If it has no effect then you can just put it back to your previous setting
I had tried all combinations to see if I could get the inners to come on with the brakes but no success
Setting this Byte to 0x15 worked for me but I have Halogens, 0x04 had strange results with the side lights.
One thing I have noticed is that when you write to the CEC it sets your coming home/leaving home/autolocks/mirror adjust etc to default values.
It's just a matter of going into the MFD and setting them back to your preferred values.  :smiley:
« Last Edit: 30 August 2010, 10:35 by mike. »
Offline Ess_Three
« Reply #24 on: 30 August 2010, 12:31 »
Right...just been for a play:
I *think* this is my original coding - I had 00 > 04 written down for Byte 18 anyway:
40180A3ED827F1C0448800846400892443550088736D8D60648000200000
Standard Xenon coding - I think!
Off - Xenons as DRLs, no rear lights on.
Auto - Xenons as DRLs, no rear lights on.
Sidelights - sidelights on, no Xenons, inner and outer standard rears.
On - sidelights + Xenons on, inner + outer standard rears, foglight OK, brake lights OK, no bulb warning.
Then:
Byte 18 > 04
40180A3ED827F1C0448800846400892443550488736D8D60648000200000
Sidelights - no sidelights, no Xenons, inner and outer LED rears.
On - Xenons on, no sidelights, inner and outer LED rears, foglight OK, brake lights OK, no bulb warning.
I ran this for months...but with no sidelights or parking lights.
Tried:
Byte 18 > 68
40180A3ED827F1C0448800846400892443556888736D8D60648000200000
Sidelights - no sidelights, no Xenons, inner rear LED lights only.
On - Xenons on, no sidelights, inner LED rears only. No bulb warning.
Tried:
Byte 18 > 21
40180A3ED827F1C0448800846400892443552188736D8D60648000200000
Sidelights - no sidelights, no Xenons, inner and outer LED rears and rear foglight on.
On - Xenons on, no sidelights, inner and outer LED rears and rear foglight on. No bulb warning.
Unable to turn off Foglight.
Tried:
Byte 18 > 15 - not sure why...had '15' written down...maybe Steve suggested 15 earlier on?
40180A3ED827F1C0448800846400892443551588736D8D60648000200000
Sidelights - sidelights back working, no rears, no Xenons.
On - sidelights + Xenons, inner + outer LED rears, foglight OK, brake lights OK, no bulb warning.
I've left Byte 18 set to '15' and wil see if I get the bulb warning up.
I'm not sure my parking lights work though...but that could be operator error!
Glen
Offline mike.
« Reply #25 on: 30 August 2010, 14:01 »
Glen, it was maybe a bit confusing from the table, the number to put in the byte is 04, 15 or 44, the hex numbers.
44 should be correct if my info is right for the Xenons, not 68 which is what I think you tried  :smiley:
Offline Ess_Three
« Reply #26 on: 30 August 2010, 14:10 »
Ahh...
My version of VCDS won't let me change anything using the long coding helper - not sure if any will? So I'm just cut/pasting the long code with a change of value, hence my trying 68 (and a lack of undewrstanding of Hex)...I'll try 44.
My laptop is mid sync just now...but I'll try it as soon as it's finished and let you know.
Offline Ess_Three
« Reply #27 on: 30 August 2010, 15:20 »
Mike,
44 is no good.
40180A3ED827F1C0448800846400892443554488736D8D60648000200000
Sidelights - sidelights back working, inner and outer LED rears, no Xenons.
On - sidelights + Xenons, inner + outer LED rears, foglight OK, brake lights did not appear to work (relying on reflections to check)
Bulb warning up on dash.
I couldn't see the brake lights coming on, whereas I could with '15'.
Bulb warning straight up...set back to '15' and all is well again...no bulb warning, all lights work as they should (Xenons as DRLs, sidelights, dip & main Xenons, all indicators, foglight, reversing light, brake lights..and no bulb warning.
I've left Byte 18 set to '15' and will try it for a while.
How do you get the parking lights to come on?
I can't seem to get them to work...but may be trying it wrong.
Is it indicator left down before ignition goes off?
Offline Ess_Three
« Reply #28 on: 30 August 2010, 15:48 »
Just checked again...everything bar the 'Auto' function when the light drops....I'll check that later on...but it's never not worked before so I expect it'll be OK.
Byte 18 set to '15' works for me for factory Xenons and R LED rears.
All lights work as they should, parking lights do work, brake lights, both inner and outer rear LEDs on with sidelights/on, Xenons as they should be, sidelights as they should be, indicators all fine, foglight & reversing light both working fine.
I'm sure I tried '15' when I first fitted the rear LEDs...but obviously not.
It appears mine is the opposite of what's suggested here for 15/44.
Quote
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #29 on: 30 August 2010, 16:06 »
The codes from Germany as a guess may only work on LHD versions  :sad:
Heres a scan of P3eps CE unit on his R it maybe some use or may not.  :undecided:
ddress 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 48180A3A9825F10044080080240008E443550088736D8D60E48000240000
   Shop #: WSC 01357 011 00200
   Part No: 1K2 955 119 F
   Component: Wischer 26021  21  0512
   Coding: 009795
   Part No: 1K0 955 559 AH
   Component: RLS 020310 05  54  0403
   Coding: 0330AD
   Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
No fault code found.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
