Author Topic: rear brakes mk2 golf  (Read 4798 times)
Offline leeroy20vt
  • h reg mk2 gti
« on: 23 August 2010, 18:22 »
as u know im in the middle of building a mk2 track car with mk3 running gear
we have put mk3 disks on back and a willwood bias valve but took it for a quick drive up road today to test brakes after they were bled and the rear is locking even with the bias valve wound right off
what can i do to further reduce fluid to rears i have some reducers out of a mk1 cab is this a possabillity if so where in the system should i put them ?
cheers lee
VeeDubGTI16v
Re: rear brakes mk2 golf
« Reply #1 on: 24 August 2010, 09:45 »
i know someone with a nova track car who runs two bias valves to reduce the flow enough
there is also a way of modding an old mini brake bias valve and this will have a range of 0-100% flow. The downside is the valves are hard to find!
also what pads are you running front and rear?
Offline leeroy20vt
  • h reg mk2 gti
« Reply #2 on: 24 August 2010, 14:29 »
green stuff pads with grooved disks up front oem at rear i have heard about the mini bias but as i have never seen one im not sure what they look like
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 25 August 2010, 12:07 »
Sounds like a reasonable solution.
You could try calling a motorsports provider to see what they suggest.  It may be some bias valves wind off more than others.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #4 on: 25 August 2010, 12:36 »
cheers fella if u have a looky in mk2 section i have started another post see what u think from that im confussed now lol mixed info all over the show lol
VeeDubGTI16v
« Reply #5 on: 26 August 2010, 08:06 »
re the mini valve being hard to find, i have just been ponted in the direction of mini spares  :grin:
http://www.minispares.com/Product.aspx?ty=pb&pid=36159&title=
the basic valve
http://www.minispares.com/Product.aspx?ty=pb&pid=38406&title=
one with screw already fitted for manual adjustment (replaces a spring that it uses as std to change the bias as susp travels)
the brake line will go in the bottom, out the side and block up the redundant side hole with a bleed nipple or something
not cheap new though  :cry:
« Last Edit: 26 August 2010, 08:13 by veedubgti16v »
Offline leeroy20vt
  • h reg mk2 gti
« Reply #6 on: 26 August 2010, 13:56 »
cheers veedub think its all good now i have put the reducers in and seems to be working fine this saturday will tell and i cant wait now as long as its not wet  :smiley:
