Author Topic: Got a MK2 :D  (Read 4166 times)
mrwotto
Re: Got a MK2 :D
« Reply #20 on: 19 January 2005, 10:27 »
Not noticed that one myself, but if free says they are there then I will take his word for it till i get chance to inspect later.
No problems with running in the cold yet tho.  So free may well be right!
Re: Got a MK2 :D
« Reply #21 on: 19 January 2005, 10:42 »
Ok, basically on the end of the air feed to the carb there should be a cool feed to the wing which isn't too important tbh.  There is also a second hose which clips into the bottom part below where the round lump with the vac pipe going to it, this feeds to a metal shroud bolted to the exhaust manifold.
It is needed along with metal shroud, mine sheared off a few months back. I thought I could get away with just tucking the pipe next to the manifold but I got problems with carb icing. The car would often stall at lights, even with the cold air feed removed.  I clamped the shroud back on with 2 jubilee clips at the weekend and its been fine ever since!
Offline audiquattro
Re: Got a MK2 :D
« Reply #22 on: 19 January 2005, 10:52 »
Carb icing can be strange. I've had a few carb vw's in my time, and the warm air hose always breaks.
I never did anything about it and never had any problems, i must of just been lucky!  :laugh:
free
Re: Got a MK2 :D
« Reply #23 on: 19 January 2005, 11:01 »
dont matter if its there or note mate, they still do it,,,,,,, well mine does :angry: :angry: :angry: ? ALL THE TIME
Offline audiquattro
Re: Got a MK2 :D
« Reply #24 on: 19 January 2005, 11:07 »
But haven't you got a gti mate?  :laugh:
Re: Got a MK2 :D
« Reply #25 on: 19 January 2005, 11:26 »
Free if it still does it theres summat up with it elsewhere!
Audiquattro: Agreed, I think it depends on the car wheather it happens or not, you got a 1.8 or a 1.6?  Mines a 1.6  :smiley:
Offline audiquattro
Re: Got a MK2 :D
« Reply #26 on: 19 January 2005, 14:20 »
I used to have a driver 1.6 and a GL 1.8 auto, long time ago, since moved on to fuel injection  :laugh:
Re: Got a MK2 :D
« Reply #27 on: 19 January 2005, 14:32 »
Lucky you eh  :grin:
mrwotto
Re: Got a MK2 :D
« Reply #28 on: 19 January 2005, 15:52 »
I have a 1.8 carbed GL and a 2litre 16 valve multi point injection MK3 :D :D :D :D
