Author Topic: 3000 miles and one new starter motor!  (Read 4553 times)
Offline ronnie'C'
  • MKVI GTi and a MK3 VR6 (lhd)
Re: 3000 miles and one new starter motor!
« Reply #10 on: 20 August 2010, 12:09 »
anyway starter motor replaced and no problems yet :huh:
thats a strange one
Offline Keithuk
« Reply #11 on: 20 August 2010, 12:28 »
You sure there isn't an auxiliary pump that runs after the engine turns off? My polo 1.8t had one.
An auxiliary pump to do what? There may be one on the Polo Kenny but it won't be a water pump.  :wink:
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline KennyGTI
« Reply #12 on: 21 August 2010, 10:03 »
Think about it Keith for a second. Your driving your car pretty hard over some back roads, into the high rev range in all the gears, turbo is spooling liek mad etc then you stop and turn your engine off, what cools the turbo and engine? This little chap I have posted below (click on link below). Its there to keep the oil cool so the oil doest cook your turbo shaft! These can run for up to 10 mins.
http://www.ecstuning.com/Volkswagen-Golf_IV--1.8T/Engine/Cooling/Water_Pump/ES2710/
Feel free to have a look about google if you still doubt me  :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink:
« Last Edit: 21 August 2010, 10:04 by KennyGTI »
APR Stage 2+
Offline entropy
« Reply #13 on: 21 August 2010, 10:52 »
ha sounds like your car was built on a Monday!
Offline Keithuk
« Reply #14 on: 21 August 2010, 11:40 »
I'm not doubting you Kenny its something I've never heard of. You learn something everyday. That may have been fitted on some engines but not the GTD engine.
Harvey was saying that a new starter motor cured his faulty noise.  :wink:
Offline Ess_Three
« Reply #15 on: 21 August 2010, 11:45 »
Te run on pumps aren't fitted to the Diesels I don't think...I believe it's to do with the much lower EGTs on diesels, and hence the turbos don't get as hot, so don't need it.
..but gaining motorcycles.
