Author Topic: 1.8 issue  (Read 4434 times)
Offline ralphtown
Re: 1.8 issue
« Reply #20 on: 04 September 2010, 18:48 »
Will do matey.
Just to add to the sum of human knowlege :)
By the way,where is the idle control valve located?
I,m reading cleaning this can produce amazing results :)
RALPH
Offline ralphtown
Re: 1.8 issue
« Reply #21 on: 07 September 2010, 09:06 »
The fuel pressure figures I gave are for multi point injection cars.
Single point engines run at 0.8 to 1.5 bar.
Just to clarify.
RALPH
Offline ralphtown
Re: 1.8 issue
« Reply #22 on: 23 September 2010, 08:53 »
The Car is Sorted!!
Got a bit fed up with it and lots of "experts" who should know better telling me it was anything from the wrong throttle body to a screwed ecu.
Turned out to be the 4 wires from the lambda plug in.
Thats the plug into the car,not the wires on the lambda sensor.
So,if you have issues with your Mk3 failing on high lambda readings,get those wires checked before you replace a thing.
You,ll save yourself a fortune.
RALPH
