Author Topic: No Beading  (Read 5442 times)
Offline javalin
Re: No Beading
« Reply #20 on: 20 August 2010, 14:41 »
yeah - wouldn't do it regularly, but probably ok for a once off.  You just need to clear the wax off so the sealant will "stick"
my mk3 looks like this after:
 :smiley:
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline MDSS MK6
Re: No Beading
« Reply #21 on: 20 August 2010, 16:07 »
If you're going to do it properly, get a soft clay bar kit like this
 http://www.waxamomo.co.uk/productcart/pc/viewPrd.asp?idproduct=322&idcategory=4
Much better way to clean up any old wax & a load of other bonded on rubbish. It also leaves you a perfect smooth surface. Give it another wash, then do 2 layers at least an hr apart of whatever wax you go for (and the dodo range all come in small sample pots that'll do a good few cars, so you can try without spending much cash). Colly might last a bit longer, but the dodo rocks looks wise). :cool:
Cancelled Order
Mk5 R32 instead.....and change too:)
Offline javalin
Re: No Beading
« Reply #22 on: 20 August 2010, 16:10 »
yeah deffo clay it first! :-)
Offline am1w
Re: No Beading
« Reply #23 on: 20 August 2010, 19:29 »
I am so daft and blind that I thought the post said 'No bleeding'! :rolleyes:
Offline musicman87
Re: No Beading
« Reply #24 on: 24 August 2010, 12:21 »
Its all in the prep. Definitely clay it all over, then polish with some decent stuff.
2 thin coats of Jetseal109 - (I used it for the first time this weekend, brilliant stuff, makes the car shine so much deeper)
Then top it off with a coat or two of Wax. I use Meguiars Techwax 2.0 and this is good, i get good beading, but AGHD should be ok. I have a mate who uses is on his Clio 172 and his beads loads!
55' Tornado Red 3-Door GTI, Manual, 17" Monza's, Totally original!
Offline KennyGTI
Re: No Beading
« Reply #25 on: 24 August 2010, 12:29 »
Just done a full detail (clay, machine polish, AGHD to finish) on someones Clio CUP at the weekend and it came up like new! Lots of beading afterwards! Made my Golf feel very jealous!  :undecided:
APR Stage 2+
Offline javalin
Re: No Beading
« Reply #26 on: 24 August 2010, 13:06 »
just your GTI to do now then....  :smiley:
Offline KennyGTI
Re: No Beading
« Reply #27 on: 24 August 2010, 16:41 »
I know, but don't get paid for doing my own!  :grin:
APR Stage 2+
