Author Topic: Urgent help needed please!!!  (Read 2446 times)
Offline boneybradley
  • Back in a Mk3...
Re: Urgent help needed please!!!
« Reply #10 on: 14 August 2010, 10:47 »
I would also check the rubber gasket for the spi unit and the temp sensor
Offline sean080181
« Reply #11 on: 14 August 2010, 12:13 »
Ok so replaced plugs and leads and the same thing!!! when taking the air box on top of the throttle body off i noticed oil in there!!!
Im no expert but that cant be good!!
Also now when the engine is turning on the starter the oil light now flashes!!!!
Things dont seem good
Offline dom
  • Back in a Mk4
« Reply #12 on: 14 August 2010, 14:51 »
How much oil was there? Mine always has a little bit that needs to be wiped off, i'd always assumed that this was normal.
Offline sean080181
« Reply #13 on: 14 August 2010, 15:52 »
Starting is now sorted after cleaning up the tb but new problems now.
The idle is erratic on start up, very high and the oil light flashes and beeps randomly when driving then stops  then starts again with no pattern???
what could this be now
cheers
