Author Topic: mk3 gti wont start  (Read 5451 times)
Re: mk3 gti wont start
« Reply #10 on: 14 August 2010, 22:10 »
If it is a AGG the immob is built in and you will need the chip inside the key.
Offline Griff76
  • If only everything in life was as reliable as a...
« Reply #11 on: 16 August 2010, 16:42 »
Cheers for the advice got the old girl running again, swopped the ignition for the one in my 1.6 ( in bits head gasket) Its not ideal cos it has no chip so im using 2 keys!!!!! But will do for now. Does anyone know the best place i can get an ignition with keys, might check my local scrapyards. Also cut out once but not as bad as before could this be throttle body needs cleaning? Happy daysjavascript:void(0);
Offline kr1s77
« Reply #12 on: 16 August 2010, 23:06 »
Try adding a push button start, that way u can keep your original key and barrel.
ASV 1.9 TDI 110
