Author Topic: Couple of niggles...  (Read 2717 times)
Offline dom
  • Back in a Mk4
« on: 12 August 2010, 23:01 »
As per title, after being on holiday and not driving for a week I noticed a couple of things that I hadn't noticed when driving it daily.
Firstly when travelling at any speed over about 85mph the car begins to feel a bit unsettled and the steering slightly lighter. Coilovers have been on a for a few weeks and have bedded in, I fitted new top mounts all round when changing suspension and tracking/camber is spot on. What else could cause this?
Secondly, how much should the engine block move when pushed by hand (if at all!)?
Finally I think I caught a couple of lorry drivers sleeping when flying up the M6 the other night and got cut up a couple of times, had to hit the brakes fairly hard and got some severe steering wheel wobble and a little bit of pulling to the left. Is this likely to be a warped disc(s)??
Cheers  :cool:
Offline sharki786
  • GOT BOOST??
Re: Couple of niggles...
« Reply #1 on: 12 August 2010, 23:09 »
about the brakes think they warped ive got same prob!!  :angry: only fitted mine nearly 2 yrs ago aswell! ragged of bad! engine not ment to move much as i have an 8v agg engine code
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Cable
« Reply #2 on: 13 August 2010, 01:48 »
Steering will always feel lighter at higher speeds, check all of the bushes and ball joints front and back, and replace the ones that have play
Engine mounts should only let the engine move a little
Pulling to the left and steering wheel shaking also link to checking the bushes and ball joints.
But the shaking might be the disks
Offline archie837
« Reply #3 on: 13 August 2010, 07:49 »
+1 for checking your bushes. We were trying to find a clunking on a mates bora and it was only when someone drove it and slammed the brakes on that we noticed the movement in the wheel - it was moving forward and back in the arch.
Project longterm Airbanger.
PD150 Anni daily
« Reply #4 on: 13 August 2010, 10:47 »
Yep :afro:
Offline Stirring Moose
« Reply #5 on: 13 August 2010, 13:24 »
Condition of bushes and such can certainly give wheel wobble, although I've never had it on the Golf as yet. Are you running anything trick in the way of tyres? Both my father and I switched to track day type tyres (Avon CR6ZZ on a Sunbeam Tiger and Yok 032R on a Mini respectively) and we both hit wheel vibration problems that were only solved by full rebushing of the front suspensions. The Mini in particular really suffered under braking. Disc warping is also a possiblity. Have you tried sticking a DTI against the disc to check this?
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
Offline dom
  • Back in a Mk4
« Reply #6 on: 13 August 2010, 13:45 »
Cheers for the replies guys :afro:
Re: bushes/ball joints - no play
Re: Engine movement - I can rock it backwards and forwards about an inch fairly easily, would that be classed as normal?
Re: Discs - i'll check them all over the weekend when I have a bit more time
S.M.
Tyres are nothing special 195/45/15 Uniroyal Rainsports, only a few weeks old, so i'd be suprised if they were the cause.
« Reply #7 on: 13 August 2010, 17:36 »
Engine movement does sound a bit excessive. Quick scout around the engine mounts might be in order. I had to have mine replaced a little while back. Might be particularly necessary if you've had any oil leaks as the oil will rot the rubber in the mounts.
S.M.
Offline dom
  • Back in a Mk4
« Reply #8 on: 13 August 2010, 20:35 »
Yeah it feels like more movement than there should be!
Stupid question but how many mounts are there and where abouts can I find them?
Offline harlemex
« Reply #9 on: 13 August 2010, 23:04 »
Three. One at the front, one under the gearbox, and the difficult to get at one at the rear on the left.
