Author Topic: Anyone use spring assistors?  (Read 3086 times)
Offline fishnchipsx2
Re: Anyone use spring assistors?
« Reply #10 on: 13 August 2010, 19:33 »
Yeah, if you decide to grind back the rear arches, make sure you don't grind past the spot welds holding the 2 skins together.
I've used an arch roller before, and IMO, it was pants.  Better results were achieved using a hammer and dolly.  Just be sure to scrape off the underseal behind the rear arches before starting (heat-gun helps) so you can fold the lips back flat.
Offline Diamond Hell
  • Opinions я Us
« Reply #11 on: 13 August 2010, 20:59 »
Maybe try fitting the right wheels?  :rolleyes:
Offline Mr Blue
« Reply #12 on: 13 August 2010, 21:17 »
or skinny tyres :tongue:
Dont cut the rear metal arch. Just roll it
