Author Topic: 16v gearbox refresh  (Read 1004 times)
Offline tony_ack
16v gearbox refresh
« on: 09 August 2010, 23:39 »
I've just had my clutch changed and have been told that the gearbox is about to throw its diff. 2nd gear is crunching as well, but I've hopefully managed to source a second hand 2y box which has done about 120k miles.
The garage that did the clutch will fit the new box at a discount. However is there anything I should do to the new box before it is fitted?
I was thinking new seals, possibly bearings too? Can you get a bolt kit to replace the differential rivets too? I've got some Redline MTL I was going to chuck in the old box, so it looks lke that will be going in the new one. Clutch is 100 miles old, so doesn't need replacing yet  :smiley:
Any advice and VW part numbers or parts sources would be appreciated. I don't want to go to the length of a full refurb on the new box as the engine (standard KR) is on 165k now and I may eventually go ABF if/when it goes bang..
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline Reasty
  • Alpine white valver.
Re: 16v gearbox refresh
« Reply #1 on: 10 August 2010, 07:50 »
I'd at least have the oil seals replaced as when I put another box on mine we found out a few weeks later that the oil seals where shot and at over 100k I'd say ud be better of getting them done,only bowt £15 from www.transmission-rebuild-kits.co.uk
They do everything from seals to bearings to full rebuild kits for the o2y box.
