Author Topic: Archies Volksrod - []o\_|_/o[]  (Read 192640 times)
Offline archie837
Re: Archies Volksrod - Forward progress!
« Reply #50 on: 05 May 2011, 15:49 »
Dropped the gacky gearbox to clean up
Dropped the beam extender and pulled the gear rod out
First pan in
2nd pan going in
Fully seam welded and taken for a test drive
Hasn't fallen over yet!
CSP axle adjusters come by post
Project longterm Airbanger.
PD150 Anni daily
Offline archie837
« Reply #51 on: 19 June 2011, 19:35 »
Haven't updated this for a while.
tackled the beam / axle adjusters today. these allow you to dial in the ride height you're after by dropping the front end.
Spensive CSP adjusters, worth it though
They;re grooved each side and go together like so
one manky beam
Starting to clean it up
Axle adjuster goes like so -
PD150 Anni daily
Offline archie837
« Reply #52 on: 19 June 2011, 19:36 »
We needed to cut a slot so the threaded bit can spin the leaves round to allow the ride height to change
Slots cut
With the adjusters bolted on
The beam had crimps / dents on the top and bottom holding the inner beam / leaves in place. We cut these out to allow the inner beam to spin freely and I then made some fill plates / bits and Mr Welder welded em in.
Just need to clean the welds up and jobs a good un. On the 17" steels with quite tall profile tyres it left about 2 to 3" under the beam so pretty low. I'm going to run dropped spindles as well, so expecting this to lay the beam on the ground.
PD150 Anni daily
Offline archie837
« Reply #53 on: 19 June 2011, 19:36 »
finished the beam bits for now
PD150 Anni daily
Offline archie837
« Reply #54 on: 19 June 2011, 19:37 »
Good day today! Floors finished up underneath so now solid. Also lopped off the jacking points and made my own instead which are not so bulky.
Pics!
Upside down floor
Old jacking point
Lopped off!
New one mocked up
Weldingz
New jacking point in
just needs cleaning up and can paint it!
PD150 Anni daily
Offline archie837
« Reply #55 on: 19 June 2011, 19:37 »
had a good day today as well. Feels like I'm not making progress, but making one off bits and doing a proper job, with only one day a week is the reason for that. Soo went down today for a play. reshimmed one side of the floor as it wasn;t square with the oppositte side. This would mean the body wouldn;t sit square. Also finished off one side of the jacking point as well.
Slicing the back for a rejiggle
Cleaning up the box section
made 8 of these!
To do this
And cleaned up!
Looks much better now. Won't be on it next weekend as I'm in portugal with work. It's a hard life sometimes.
PD150 Anni daily
Offline Horney
Re: Archies Volksrod - Lots of new pics.
« Reply #56 on: 19 June 2011, 20:15 »
Good work fella :cool:
« Reply #57 on: 19 June 2011, 21:00 »
Cracking work :afro:
Offline archie837
« Reply #58 on: 19 June 2011, 21:23 »
Cheers guys! I know it won't appeal to a lot of people on here, but thought it would be cool to share
PD150 Anni daily
Offline dom
  • Back in a Mk4
« Reply #59 on: 19 June 2011, 22:41 »
I think most people will appreciate the skills that are needed to carry out a project like this, top work :cool:
