Author Topic: Anti-roll bar diameters  (Read 1288 times)
Offline dubdriver
« on: 07 August 2010, 23:57 »
Hi,
I was wondering if someone knew what the anti-roll bar diameters were for a 1.8, would a VR6 or GTI have thicker anti-roll bars or are they all the same in the mk3 range?
Many thanks.
Offline broken-passat
  • tdi wagon .....
Re: Anti-roll bar diameters
« Reply #1 on: 08 August 2010, 08:35 »
if you go to the powerflex web site they tell me there is a choice of 18mm or 20mm , but no models listed . so just a choice of 2 . hope that helps
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 08 August 2010, 12:05 »
18mm on the non gti/vr models
Offline Len
« Reply #3 on: 08 August 2010, 14:01 »
Seen some 25mm but cant remember where!
www.sas.org.uk
www.the-ace.org.uk
Offline tshirt2k
  • Been there...Done that...
« Reply #4 on: 08 August 2010, 18:47 »
Gti 16v and vr6 have the plus axle suspension so not as easily interchangeable.
Mk3 ABF 16VT Megasquirt V3
Offline dubdriver
« Reply #5 on: 08 August 2010, 18:58 »
Cheers guys, what would you guys suggest to reduce the roll on my 1.8 driver. I want to maintain ride quality and keep it looking as standard as possible, should i try to replace the standard anti roll bars with vr6 or gti ones. Or alternatively fork out £200+ for some eibach, weitec etc upgraded ones?
Offline tshirt2k
« Reply #6 on: 08 August 2010, 19:03 »
Gti/vr6 arent a straight swap as they use different drop links. Eibach would probably be best but you would have to change front and rear as front only can induce more understeer.
